I just lost reverese! how much for a bearing and synchro kit???
Old Sep 13, 2007 | 03:38 PM
allnaturalb16's Avatar
Default I just lost reverese! how much for a bearing and synchro kit???
How much would it cost to buy a synchro and bearing kit for a ys1 tranny?
About how much would it cost to repair if I brought someone the tranny?
Old Sep 14, 2007 | 07:26 AM
Default Re: I just lost reverese! how much for a bearing and synchro kit??? (allnaturalb16)
i have been looking and cant find exactly what i need. can anyone shed some light on the situation, or even point in the general direction. It would very much appreciated. thank you
Old Sep 14, 2007 | 08:49 AM
Lubo_25's Avatar
http://www.gearspeedinc.com...
Old Sep 14, 2007 | 11:22 AM
Mista Bone's Avatar
D Tranny Guru
seller acerl on ebay
Old Sep 14, 2007 | 06:17 PM
cinci27's Avatar
Default Re: (Mista Bone)
Reverse typically doesn't have a syncro. Surprisingly, it's even in the basic owners manual for my civic.
Reverse is square cut, so it'll definitely grind if the input shaft is still rotating. that's why putting it in a different gear first usually prevents the grinding....it uses the other gear's syncros to slow it down and/or gives enough time for it to stop spinning.
Old Sep 14, 2007 | 07:33 PM
Mista Bone's Avatar
D Tranny Guru
I'm sorry, but every 1992-2001 B series tranny has a revesre synchro, it's mounted next to fifth gear.
Old Sep 17, 2007 | 02:44 PM
I am just going to take it to AAMCO. Gearspeed wants 1,400 to rebuild it and I dont have that cash.
Old Sep 17, 2007 | 03:15 PM
Lubo_25's Avatar
Default Re: (allnaturalb16)
grab a service manual and save some cash man...
Old Sep 17, 2007 | 03:31 PM
Default Re: (Lubo_25)
no time...and i want it done right. I have never worked on a tranny.
Old Sep 18, 2007 | 10:07 AM
Lubo_25's Avatar
theres no way to expletive it up with an oem service manual containing every tolerance...but to each their own good luck comrade
Old Sep 18, 2007 | 11:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 &raquo;</TD></TR><TR><TD CLASS="quote">theres no way to expletive it up with an oem service manual containing every tolerance...but to each their own good luck comrade </TD></TR></TABLE>
tools needed?
time to actually do it (1st time)?
not really sure whats needed because of inexperience so I have no idea really what parts to buy?
the labor is only $300-400 i think i would be best off spending it
you gave me a little hope though, if i had the time and what not i would try
Old Sep 18, 2007 | 04:02 PM
Lubo_25's Avatar
no worries man if the labour is around there go for it just make sure they know what thrusts and clearances to check for...all the tools are explained in the service manual most of the tools though are commercially available...but honda still tries to make them look special you can make some too theyre simple designs...i know i couldnt charge that 400$ for a tranny rebuild too much inspection and measurements for that cheap of price to spec everything out a shop will charge around a solid g where i live...good luck comrade
Old Sep 19, 2007 | 06:59 AM
Thanks Ill need it...
I found a good place for "honda/acura" but they want 1400.00
I found another place that does a really good job on imports in general and they Only want 350 plus parts but I cant get a "real" or even close price on ALL of the parts I need. do you have any idea on how much (rough estimate) everything would be as far parts needed for a rebuild plus reverse synchro?
Old Sep 19, 2007 | 08:25 AM
Lubo_25's Avatar
my friend i couldnt tell you a rough estimate depending on how old a transmission is and how it was treated you have to check for many tolerances countershaft, main shaft runout, gear thicknessess, synchro teeth conditions, seals, bearings etc...these things have to be taken apart and checked thoroughly on what needs replacing and what doesnt and even then some components need to be replaced in sets like synchro hubs with sleeves...i just hope the shop you take it to can be trusted with these sorts of things because the shops around here you cant trust people around here with japanese engineering...there is a reason why gearspeed charges so much they stand by their work im not trying to promote business there im just saying how much time and sweat it takes to fully spec out and rebuild a honda trans...dont know what else to tell ya man...
Old Sep 19, 2007 | 10:50 AM
well where i am going they offer a 2-year 30k mile warranty.
about how much does a new FD cost? (just for the part)
about how much would a close ratio 1:1 5th gear cost? (just for the part?)
Old Sep 19, 2007 | 11:48 AM
Lubo_25's Avatar
i have no idea about prices off the top of my head...lol that would be insane but the warranty sounds good though try that place out...if theyre good then theyre good only time will tell...
MalcolmV8
Transmission & Drivetrain
49
Jul 20, 2011 06:07 PM
95LSv
Honda Civic (2001 - 2005)
Apr 1, 2010 06:09 PM
1xfastxhatch
Mar 5, 2009 07:07 PM
lukehowell88
Nov 26, 2007 12:38 PM
pa2play
Feb 23, 2005 12:01 PM
