what are best way to install/adjust the BC racing spec dampers
Old Jun 16, 2002 | 08:22 PM
Anderson's Avatar
Default what are best way to install/adjust the BC racing spec dampers
hey dudes,
my bud just got a set of BC racing spec dampers **drool, i want some 2 ** , we'll install da BC's on his R next week but just wondering what are the best way to install and adjust the damper height, and other setting adjustments? We both have never install a set like BC's b4 (i'm sure it's all da same) so. any advice and input would be cool.
what are the best height/ setting adjustment for them on Street and Track?
thanks dudes.
Old Jun 17, 2002 | 05:07 AM
B18CXr's Avatar
Default Re: what are best way to install/adjust the BC racing spec dampers (Anderson)
you have IM
Old Jun 17, 2002 | 05:41 AM
ZygSpeed's Avatar
Default Re: what are best way to install/adjust the BC racing spec dampers (B18CXr)
you have IM
Pass some of that good info this way too, Jack!
Thanks, I'll be installing mine soon as well. Ed
Old Jun 17, 2002 | 10:31 AM
KekeK-18's Avatar
I Just ordered some BC from R&D too, can you pass along the secret info to me also? It seems like I need to take the whole suspension out everytime to adjust the ride height?
Old Jun 17, 2002 | 10:42 AM
RagingAngel's Avatar
Default Re: what are best way to install/adjust the BC racing spec dampers (KekeK-18)
It's a coilover you should be able to just turn the perches on the car to raise and lower at will...
just put the car on jackstands rip the wheels off and away you go!
Old Jun 17, 2002 | 11:01 AM
EFFECT's Avatar
Default Re: what are best way to install/adjust the BC racing spec dampers (RagingAngel)
Ive done 2 sets of em, and just disconnected the bottom of the shock from the fork/LCA and spun the bottom threaded part, since on the buddy clubs you adjust the shock length for ride height, and use the adjustable spring perch to set the preload
Old Jun 17, 2002 | 12:19 PM
Anderson's Avatar
Default Re: what are best way to install/adjust the BC racing spec dampers (EFFECT)
thanks for the reply
but i'm stupid dont know what LCA is. and what's " setting prelaod"? sorry dude.
kyleag989
Honda Civic (2001 - 2005)
Feb 5, 2018 03:20 PM
TastyDragon
Dec 2, 2006 03:09 PM
lalaine17
Acura TSX
Aug 28, 2006 12:37 PM
Goatsterrman
Audio / Security / Video
24
Nov 20, 2004 08:10 AM
