Problem with Blox Front Camber Kit.
About a week ago, I purchased a Blox front camber kit. After removing the stock upper control arm and attempting to install the Blox upper control arm; I discovered that the holes were too small for the stock bolt to fit through.
Anyone else encounter this problem?
The Blox kit is currently being shipped back for a refund. I'm going to go with the Skunk2 Pro-Series Plus instead.
By the way, this was being performed on a '95 del Sol Si
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloAZSol »</TD></TR><TR><TD CLASS="quote">About a week ago, I purchased a Blox front camber kit. After removing the stock upper control arm and attempting to install the Blox upper control arm; I discovered that the holes were too small for the stock bolt to fit through.
By the way, this was being performed on a '95 del Sol Si </TD></TR></TABLE>
not sure about blox, but i currently am using ingalls front and rear upper control arms and never had a problem (yet).
For follow up-the oem bolts fit in the Blox camber kit on mine with no problem at all. Maybe you were sent the wrong kit with the right label or something?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrob »</TD></TR><TR><TD CLASS="quote">For follow up-the oem bolts fit in the Blox camber kit on mine with no problem at all. Maybe you were sent the wrong kit with the right label or something?</TD></TR></TABLE>
could be, SloAZSol can you follow up on the blox camber kit situation. See if it was the right application for your car.
Just noticed this now, but here's my follow-up.
I received the BLOX camber kit in a box labeled for 92-95 Civic/94-01 Integra. So it was labeled correctly.
I returned it for a Skunk2 Pro+ kit. Fits and performs perfectly.
down_the_hatch
10
Feb 17, 2005 06:40 AM
IntegraFanatic
Apr 6, 2004 11:15 AM
19civic93
39
Mar 24, 2004 05:40 PM
ruiner17
16
Feb 24, 2003 10:48 AM
azn_outlaw
Jan 19, 2002 05:03 AM
