thowing codes 22 and now 21.
Old Sep 13, 2007 | 01:26 PM
Pr0ject93hb's Avatar
Default thowing codes 22 and now 21.
I have a 93 civic with a turboed ls vtec setup. for a little while now whenever i hit vtec for any time i would throw a check engine light (code 22 Vtec pressure valve), i was told i could possibly fix this by removing the vtec solenoid and cleaning the small mesh screen inside with parts cleaner. i never got around to it, and when i would turn the car off the code would go away, and since i rarely hit vtec since i daily my car, it was really a high priority.
now today i noticed that the check engine light was coming on right away and would not turn off, so when i jumped it i noticed the normal code 22 along with a new code of 21 (Vtec spool solenoid valve) i have no idea what this code is, other then im guessing it controls vtec. any ideas on how to fix this?
Old Sep 13, 2007 | 01:31 PM
crazyguy's Avatar
Default Re: thowing codes 22 and now 21. (Pr0ject93hb)
try to clean vtec solenoid with brake cleaner and then hot wire it to hear if it clicks...u cant run vtec without solenoid.
that reminds me that i have to clean my vtec solenoid this weekend.
Old Sep 13, 2007 | 02:11 PM
Joecivic94's Avatar
Default Re: thowing codes 22 and now 21. (crazyguy)
code 21 is the vtec oil pressure plug. Also how do you hard wire the solenoid i need to try that.
Old Sep 14, 2007 | 09:42 AM
Default Re: thowing codes 22 and now 21. (Joecivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joecivic94 &raquo;</TD></TR><TR><TD CLASS="quote">Also how do you hard wire the solenoid i need to try that.</TD></TR></TABLE> yes, how is this done? and do i just replace the vtec pressure plug?
Old Sep 14, 2007 | 09:50 AM
crazyguy's Avatar
all pm'ed
dwr1977
Mar 2, 2012 02:34 PM
ghettoSi
Jan 11, 2008 11:39 PM
ganjasnack
Jun 11, 2007 02:38 PM
dkboyny11
Jun 2, 2005 03:45 PM
Metrocity2
Apr 27, 2005 02:03 AM
