front itr endlink 90 degree question
setup for the front sway:
95 civic cx hatchback
itr sway bar
del sol si flca
now my question from all the searching i have done is; how long is the actuall link from acura they are over 50 dollars per link and from the parts store i found a set for 20$ i just need to know specifically the how long the endlink is. also what links are you guys using and will they work with the del sol si lca
itr sway bar
del sol si flca
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 06sik20z3 »</TD></TR><TR><TD CLASS="quote">setup for the front sway:
itr sway bar
del sol si flca
the lower control arms will work since they are the same, but the endlinks you plan on buying from the parts store will not work.
the ones at the store are for swaybars that sit horizontal at each end. you are going to have to save up and get them from the dealer.
itr sway bar
del sol si flca
</TD></TR></TABLE>the lower control arms will work since they are the same, but the endlinks you plan on buying from the parts store will not work.
