del sol say bar question
my brother has a 95 del sol S (bottom trim level) 5spd. He would like to put on a 22mm ITR sway bar, however, there are no end links on his LCAs to connect with the sway bar. i searched around a few sites, including comptech and suspension techniques (since they offer a sway bar kit for del sol w/o a sway bar (s model) and still found nothing, do i just need different LCAs?? If so, could i swap them with my 95 GSR (since i threw on a ITR suspension?? any helped much appreicateed....thanx
Re: del sol say bar question (rupace12)
the old LCA's from your gsr will work...you should also look into a subframe reinforcement kit, so you don't tear that subframe.
Re: del sol say bar question (starang)
yea i have a BSQ kit for him, have one on my GSR with a JDM rear 23mm and its fine. i guess teh Tein RS spring rate helps it a little lol
i know i can fit it with diff LCAs. the quesiton is how to do it with the stock LCAs?? it is possible b/c comptech has sway bars for this car.....the S
(=GAMEOVA
how much you looking for them?? just need both rear LCAs. how is it to replace rear LCAs?
(=GAMEOVA
since you say Comptech makes it for the "S" model, i believe itll mount like the S/T sways, which mounts on the lca bolt at the bottom of the strut. but you said he want to add a R sway bar which you need the holes to be on the LCA for it to mount on.
you have pm
you have pm
im pretty sure progress makes one
http://www.optauto.com/webstor...=1478
just noticed you wanted a type r......
GS8HFL21
01-11-2005 10:22 AM
phantom_sol
04-24-2003 01:27 PM
phantom_sol
04-17-2003 05:24 PM
