Main relay clicking fast
Old Jun 16, 2002 | 07:46 PM
SOUTHCREX's Avatar
Default Main relay clicking fast
Well i wired my dx to mpfi for my z6 and whne i try and start it, all it dose is make a really fast clicking noise coming from main relay area when the car is turn on, the when i try and turn over it sounds like the starter pops out but dosent spin, just a click, click. it not the battery because i put a jumper on it and tryed again. If anyone can give some info i would realy apreciate it.
Old Jun 17, 2002 | 01:52 AM
SOUTHCREX's Avatar
Default Re: Main relay clicking fast (TEAM GARAGE SHIFTDOWN)
ttt
Old Jun 17, 2002 | 03:30 AM
civicwagonman's Avatar
check and make sure you ahve a ground cable between the body and the transmission. sounds like a ground problem.
Old Jun 17, 2002 | 06:33 AM
EFSiR's Avatar
Default Re: Main relay clicking fast (civicwagonman)
ECU input signal is interrupted.
Old Jun 17, 2002 | 07:58 AM
EternalFootman's Avatar
Definately a grounding problem. Check your grounds to the:
- Thermostat (often missed)
- Starter
- Valve Cover
- From battery to tranny casing
I think that's all of the grounds in the engine bay, which is most likely where the problem is.
dave
Old Jun 17, 2002 | 09:41 AM
FourthGenHatch's Avatar
Default Re: Main relay clicking fast (EternalFootman)
I'm not positive but might the Si have had a different Main Relay?
Old Jun 17, 2002 | 10:52 AM
SOUTHCREX's Avatar
Default Re: Main relay clicking fast (FourthGenHatch)
Thanks for the help, im on the right track so far. Their was a wire in the back coming from the wire harness that had one of those circle connector clamps so that you can hook it through a bolt , well im thinking that it grounds on the starter, but i just grounded it . dose that wire have to be grounded on the starter or anywhere? The main relay clicking stoped, but wen i try to turn it over all i get from the starter is a click also. Thanks again for any help!
Old Jun 17, 2002 | 01:17 PM
Perfectionist's Avatar
One important ground connection is at the thermostat housing. Otherwise, overall, your description sounds like a weak battery, too.
Old Sep 26, 2003 | 06:18 PM
untitled's Avatar
Default Re: Main relay clicking fast (EFSiR)
please elaborateon the ecu input signal. fro some reason i think this is it b/c when it clicks the tach bounces real fast.
i have this same problem except it happens when the car is running and under load(%50+ throttle)
also i thought the starter only had the starter signal and 12v. regardless i dont have either of the two starter grounds.
Old Sep 26, 2003 | 08:34 PM
untitled's Avatar
Default Re: Main relay clicking fast (Garage Shiftdown)
<FONT COLOR="white">.</FONT>
Old Sep 27, 2003 | 11:10 AM
untitled's Avatar
yo
russ_512
Feb 12, 2011 05:34 PM
sirrex1990
May 13, 2010 06:29 PM
BigChina
13
Sep 5, 2008 08:58 AM
laziebun
Apr 24, 2008 11:10 AM
