knock sensor
Old Sep 13, 2007 | 09:01 AM
airborne63B's Avatar
Default knock sensor
i got a mini swap running on a jdm b16a computer. i need to know if anybody has or knows how to bypass the knock sensor without remapping the computer. could i pin the ecu and ground the wire or maybe put the knock sensor somewhere that wont read a bad vibration????
Old Sep 13, 2007 | 12:14 PM
Romulan_7's Avatar
Default Re: knock sensor (airborne63B)
Are you sure your engine isn't actually knocking?
Old Sep 13, 2007 | 12:26 PM
92_civic's Avatar
Default Re: knock sensor (Romulan_7)
plug it in and tape it to the engine harness
romulan_7...D series do not have a location on the block for a knock sensor...b16 computer will look for one
airborne63b...why not use a p28?
Old Sep 13, 2007 | 05:20 PM
Romulan_7's Avatar
Default Re: knock sensor (92_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_civic &raquo;</TD></TR><TR><TD CLASS="quote">D series do not have a location on the block for a knock sensor...b16 computer will look for one
Ah. Learn something new every day, right?
Old Sep 13, 2007 | 05:57 PM
i understand that d series do not have knock sensors. thats why im asking if there is a way to bypass the sensor. maybe some wiring or just placing the sensor somewhere else. the motor runs great just there is no vtec due to the lack of the knock sensor. its 1 wire that is pinned in i think B19 on the EF civics.
Old Sep 14, 2007 | 03:38 PM
92_civic's Avatar
I know what you were asking, that's why I said to plug it in and tape it to the engine harness, at a place where it will not vibrate, if your engine harness doesn't have a plug for it then you will have to wire it to the ecu
Old Sep 14, 2007 | 08:34 PM
4g hatch's Avatar
some ls-v guys drill and tap one of the alternator bracket holes for a knock senor.
MalcolmV8
Apr 18, 2012 10:54 AM
faxshatch
Mar 30, 2008 02:59 PM
crxb16ftw
May 20, 2007 10:31 PM
mprelude
May 18, 2005 01:20 PM
Grnade
May 2, 2005 08:45 PM
