Quick quiz: Water pump bolts?
Old Sep 13, 2007 | 08:55 AM
Utilitarian's Avatar
Default Quick quiz: Water pump bolts?
I'm getting ready to reinstall a new water pump and of the five bolts one is about 1/4" long than the others. Does anyone know which hole takes the longer bolt? I'm going to use a little hondabond and want it to seat correctly the first time.
Basically the five bolts are oriented like an upside down star so top right, bottom right, bottom, bottom left or top left?
thanks!
Old Sep 13, 2007 | 09:02 AM
jgirard's Avatar
Default Re: Quick quiz: Water pump bolts? (Utilitarian)
I'm gonna say bottom left
TODAwhore's Avatar
The top one closer to the fire wall...top right
most of the ones i've done also have a longer one at the bottom too.
Old Sep 13, 2007 | 10:47 AM
Dave_B's Avatar
LOL... one good practice to remember when working on your car...
When you take something off, put the old part and bolts aside in correct orientation (in your case bolts) so that you'll know when putting the new one on. Also, this helps when doing bigger projects not to mix some up, or end up with extra's at the end.
Some use labeled bags, I use a table with everything layed out.
Old Sep 13, 2007 | 11:50 AM
jgirard's Avatar
Default Re: (Dave_B)
So what's the answer? or do you not know?
Old Sep 13, 2007 | 11:53 AM
ironcheftony's Avatar
there are usually 2 longer bolts
but if not, the longer bolts for the water pump always go onto the holes with the "dowel pins" on it, its the metal cylinder thing sticking out
Old Sep 13, 2007 | 12:10 PM
ITRnorway's Avatar
well if you take a look at the water pump you would see that`s two holes that as thicker casting, so you would need a longer bolt to get the same thread length in the block.
(not easy for a norwegian kid to explain tech in english, but i hope you get the point)
redboardrdr
Oct 8, 2008 03:54 PM
nonvtec92
May 4, 2008 06:32 PM
pumpkyn
Jun 4, 2006 12:24 AM
jbell
May 20, 2005 01:14 AM
jmagner
May 23, 2004 07:51 AM
