Tools needed for replacing crank and balancer oils seals?
Just wondering what tools are necessary for this job? Can they be rented somewhere? If not what’s a good source to buy them at? I’m doing the timing belt on my Acura 2.3 CL. I want to make sure I have everything I need to replace the crank oil seal and both balancer shaft seals while I’m in there.
Thanks!
Thanks!
For pulling the seals out id just get a pick set to pull em out
Other than that your probably gonna need a variety of sockets/wrenches, id go with a 10,12,14,16
Plus an Impact gun or long breaker bar for the crank pulley bolt
my concern was not getting to them (I'll be doing my timing belts anyway) it was the seal drivers to get them back in,,,, I saw this set on Ebay which covers the cam seal and balance shaft seals...
http://cgi.ebay.com/ebaymotors...&rd=1
Now I just need to figure out the crank seal...
You dont need a that set, you can use a socket the same way... All the set does is you put it on top of the seal and push or tap it in.. and you can do that very same thing with a socket
pcconway
Sep 11, 2016 01:07 PM
