intake install?
Old Sep 12, 2007 | 09:01 PM
tpot90's Avatar
Default tick noise while moving.
Recently, I've been hearing a noise that has been bothering the hell out of me.
When I have my windows down, I can hear a "tick tick tick" sound that seems to go faster when my tires are going faster.
It seems like it is coming from around the passenger front tire. I don't think it matters but I just got two new tires on the front.
I dont think the breaks are sticking, either. Do you think it could have to do with the magnets they stick on the rim when balancing the tire & wheel?
Old Sep 12, 2007 | 09:07 PM
tpot90's Avatar
Default intake install?
Is there a forum on HT showing step by step installation for an intake on a 6th gen?
I search "intake install" and whatnot but it doesnt return anything.
Old Sep 13, 2007 | 04:15 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: intake install? (tpot90)
There is a link to an install for a 94-97 Accord in the Accord FAQ. It should be close enough to that for you to follow.
Old Sep 13, 2007 | 06:03 AM
The-Kid's Avatar
Default Re: intake install? (TouringAccord)
you can always go to AEM's website, Injen website to download their version of installing the intake.
Old Sep 13, 2007 | 08:20 AM
standbackimapro's Avatar
Probably a rock or somthing stuck in between the tread, or a screw or somthing.
Old Sep 13, 2007 | 10:29 AM
HondaAccordTdR's Avatar
Default Re: tick noise while moving. (tpot90)
Like was said, check for junk stuck in your tires. Sounds like the problem to me.
Old Sep 13, 2007 | 11:21 AM
JDM_DC4_Fanatic's Avatar
first off, they dont use magnets to balance the tires, those are 'sticky' weights. They are just lead weights with 2 sided tape to hold them on.
Second, if then the new tires were installed, assuming they are on the front, the tech could of slightly bent the brake rotor backing plate. Its a common problem and it makes the same noise that you have descried.
Old Sep 13, 2007 | 12:08 PM
tpot90's Avatar
Default Install complete
The only weird thing is that I couldn't take out the stock vaccum hose because its attached to something else, so i just left it hanging around.
Old Sep 13, 2007 | 12:22 PM
ex95cord's Avatar
stock vacuum hose that goes where? or where is it?
I didn't think there was need for directions to install a intake...
Old Sep 13, 2007 | 12:26 PM
tpot90's Avatar
Default Re: (ex95cord)
the stock hose was replaced with the bright blue hose that comes out of the head.
next to come..MEGAN headers
Old Sep 13, 2007 | 01:43 PM
The-Kid's Avatar
Default Re: (tpot90)
Nice job!
That hose that you were talking about, coolant runs through that. If you want to, get a coupler and put those 2 hoses together.
BTW how does it sound? I really want to do it, but I don't want that thing to be really loud...
Old Sep 13, 2007 | 04:35 PM
weezo182's Avatar
Default Re: (The-Kid)
just jump in and do it thats.
Old Sep 13, 2007 | 06:18 PM
tpot90's Avatar
Its really easy. Its just kinda hard to get to the air box bolt closest to the front of the car. I just broke it since the battery is in the way.
its not loud at idle. You can just head a growl from the filter when RPMs get hight.
I can really tell a difference. Cant wait for headers.
Old Sep 13, 2007 | 06:48 PM
96_Accord_lx's Avatar
im getting an AEM intake next weekend. hope mines looks as nice as yours. I think im going to get black flames painted on the pipe itself to add a little flava'!
Old Sep 13, 2007 | 08:28 PM
tpot90's Avatar
Default Re: (95_Accord_lx)
The only real difference between generic and name brand pipes is the quality of rubber couples and hoses..along with the filter.
Youll save a whole lot of money getting a generic pipe with a K&N filter.
A pipe is a pipe..period.
Old Sep 13, 2007 | 08:29 PM
tpot90's Avatar
Default Re: tick noise while moving. (JDM_DC4_Fanatic)
Thats not quite what I wanted to hear..but IF that is the problem, how do I fix it?
Also, I didnt notice it right away...Maybe a week or two after the new tires.
Old Sep 13, 2007 | 08:37 PM
tpot90's Avatar
Does anyone have a price range for installation of headers and/or an exhaust system?
Old Sep 13, 2007 | 08:44 PM
tpot90's Avatar
Default looking into exhaust systems
If I get headers before hand, and decided to get an exhaust system afterwards, would it be better to just get a tip, or a full 2.5" exhaust pipe all the way through?
I am wanting a low-pitch "hum," not a ricer sounding exhaust; Is there any way to judge that online? Does the diameter make a difference?
What are the differences between tip mufflers and full pipes all the way through? Any performance differences?
Also, are you suppose to use your normal catalytic converter if you get a catback exhaust, or do you have to replace it?
Modified by tpot90 at 10:30 PM 9/13/2007
Old Sep 20, 2007 | 02:35 PM
im going to get my AEM intake tonight... how long did it take?
daontejunior
Honda CR-V & Element
Apr 6, 2011 04:34 AM
Fobstylez
Acura TL, RL & ZDX
May 8, 2008 09:30 PM
killyourscene
Honda Civic (2006 - 2015)
45
Jul 18, 2007 03:13 PM
