Hondata s300 base map
Hey guys, as many of you know the hondata s300 h22a base map is not very good. Im trying to get my car up and started and im just about there just gotta plug the harness in. However I remember from prior experiences that base map barely wanted to even run the car. So i cant imagine how bad it might be now with a somewha built motor. My question is does anyone have a base map i could use for the time being to get the car to the point where i know its good and then get it tuned. The cars mods are: Its on an h22a btw
bpi velocity stack
aem 3 inch cold air intake
aebs 68mm TB
Euro R manifold
Stock 5th gen injectors (for now)
port and polished head
valve job
.004 off head
skunk stage 1 cams
supertech flat faced valves
supertech titanium retainers and valve springs
single layer HG
Camp 1320 header
bpi velocity stack
aebs 68mm TB
Euro R manifold
valve job
.004 off head
skunk stage 1 cams
single layer HG
Camp 1320 header
Take the car to a tuner instead of relying on someone else to fork over their hard earned work in hopes of having your car running. Base maps are more of a starting point for the owner/tuner to simply start up and run the engine.
i am as soon as i get it running. I have no way to get it to the tuner otherwise. Its been difficult to get a trailor. Plus i would like to know the car drives and shifts correctly before i take it to a tuner just to have some problem and waste my time and money.
Also the car with bolt ons would barely run and stalled serval times with the base map when i just messing with it awhile back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH »</TD></TR><TR><TD CLASS="quote">i am as soon as i get it running. I have no way to get it to the tuner otherwise. Its been difficult to get a trailor. Plus i would like to know the car drives and shifts correctly before i take it to a tuner just to have some problem and waste my time and money.
Also the car with bolt ons would barely run and stalled serval times with the base map when i just messing with it awhile back. </TD></TR></TABLE>
do you have a wideband?
i understand your point i hear you completely. That was my plan from day one however after many setbacks and one place canceling on me last week when i had a trailor all lined up, it makes it hard.
its not hard to get the car running then. Use some common sense and you can atleast get it to the point to where you could drive it.
just watch the a/f and adjust accordingly. If you here ping, let off the gas and pull out timing in the respective area in the map.
allwhitehonda
Jan 27, 2005 02:55 PM
