vtec pressure sensor wires?
Old Sep 12, 2007 | 08:48 PM
C_I_V_I_C_V_T_E_C's Avatar
Default vtec pressure sensor wires?
i just did a mini me swap i know that it was probably covered a million times (i think i even saw it before but i don't know ware) but i need to know ware 2 wires on the pressure sensor go. i know one gos to ground and the other on to the ecu but i don't know witch one ware and i don't have a stock plug i had to use one off another harness so clip being the top wire witch wire gos to the ecu and witch is ground?
Old Sep 13, 2007 | 11:13 AM
Default Re: vtec pressure sensor wires? (C_I_V_I_C_V_T_E_C)
ttt
Old Sep 13, 2007 | 08:56 PM
one more time
Old Sep 14, 2007 | 07:52 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_I_V_I_C_V_T_E_C &raquo;</TD></TR><TR><TD CLASS="quote">one more time</TD></TR></TABLE>We still don't know what to tell you. The ECU pinouts aren't the same for every different year...
If you know which pin at the ECU, then it doesn't matter which is which out at the sensor. It's just a simple SPST switch.
Old Sep 14, 2007 | 08:09 AM
Relic1's Avatar
the reason why you're not getting any response is that this has been covered a lot of times. it's even in several of the sticky threads in the model specific forums.
that being said which car are you working on?
OBD1? OBD2a? OBD2b?
the pressure sensor is actually a switch, it doesn't matter which connection is ground and which is connected to the ECU.
Old Sep 14, 2007 | 08:15 PM
4g hatch's Avatar
Default Re: (Relic1)
cant u just loop it to the vtec activation switch
Old Sep 14, 2007 | 08:57 PM
Default Re: (4g hatch)
its obd1 it was converted so i have the rywire harness and never had the stock clip for the sensor. like i said i know ware they go, but i didn't know witch wire went to ground and witch went to the ecu.
so it doesn't matter witch wire goes to ground or the ecu?
Old Sep 15, 2007 | 09:26 AM
Relic1's Avatar
Default Re: (C_I_V_I_C_V_T_E_C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_I_V_I_C_V_T_E_C &raquo;</TD></TR><TR><TD CLASS="quote">so it doesn't matter witch wire goes to ground or the ecu? </TD></TR></TABLE>
correct
Old Sep 15, 2007 | 04:28 PM
thank you
CivicxTree754
Apr 27, 2011 11:51 AM
Quade
Oct 14, 2008 12:56 PM
toolbox21
May 28, 2008 04:02 PM
type-t
Aug 19, 2004 06:39 PM
Lamchop0000
May 26, 2003 09:19 PM
