Gauge Faces
If i get gauge faces for my 96 accord will i still be able to see everything i do now? ie. my tach and my thing that shows which door is open and so on... how hard are they to install?
Just for your information mr. 97_accord_lx.... be advised that sometimes, these gauge faces start to come undone after a little while, and needles get stuck on them. I've seen this happening a few times, tachometer wouldn't go pass 4k rpm (gets stuck on GF coming undone).... would get stuck between 30mph and 60mph... until it just finally had a chance to come down or up again.
Use a proper resin to stick them to the stock faces. Make sure you apply it evenly over the entire back of the new faces. If you just put beads of glue, they could shrink when they dry and warp the faces, causing the needles to get stuck on the high spots.
streetmodified
41
Apr 8, 2005 10:16 AM
nocturnaldragon
23
May 3, 2004 03:01 PM
