body panel alignment
Old Sep 12, 2007 | 06:17 PM
raphael's Avatar
Default body panel alignment
i have a 00 front end on my 96 ej8. i have a lil problem where the tip of the headlight( botton corner of the housing that ends near the front grille) sticks out past the bumper and the bumper doesnt line up with the rad support. now i understand that the 99 rad support is different from the 96 support but how can it be remedied?
Old Sep 12, 2007 | 06:27 PM
scrooge's Avatar
Default Re: body panel alignment (raphael)
i dont get it did you use a 96-98 rad support? and btw wrong section
Old Sep 12, 2007 | 06:32 PM
raphael's Avatar
Default Re: body panel alignment (scrooge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scrooge &raquo;</TD></TR><TR><TD CLASS="quote">i dont get it did you use a 96-98 rad support? and btw wrong section </TD></TR></TABLE>i thought this was appearnace and cosmetic? ...
my problem is that the headlight casing stick out past the bumper where the grill is
Old Sep 12, 2007 | 06:56 PM
scrooge's Avatar
its hard to imagine what your trying to say but anyways are you using everything needed off a 99-00 civic?
hood
f bumper
2 fenders
rad support
re bar
grille
*edit* would b really helpfull if you took a pic
Old Sep 12, 2007 | 07:18 PM
.Hookedonhatch.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raphael &raquo;</TD></TR><TR><TD CLASS="quote">i have a 00 front end on my 96 ej8. i have a lil problem where the tip of the headlight( botton corner of the housing that ends near the front grille) sticks out past the bumper and the bumper doesnt line up with the rad support. now i understand that the 99 rad support is different from the 96 support but how can it be remedied?</TD></TR></TABLE>
You do not need to necessarily need to swap out the rad support. Sure in a perfect world you would or if say you were in a front end fender bender and did the swap it would make it less work to swap out the 96-98 support for the 99-00, but there are plenty of cars on here including one of my family members that have it done using the 96-98 with NO problems or imperfections at all. I recommend following this tutorial closely as this might help you with your problem http://www.jdmuniverse.com/for...rsion
good luck
Old Sep 13, 2007 | 04:40 AM
raphael's Avatar
Default Re: body panel alignment (.Hookedonhatch.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Hookedonhatch. &raquo;</TD></TR><TR><TD CLASS="quote">You do not need to necessarily need to swap out the rad support. Sure in a perfect world you would or if say you were in a front end fender bender and did the swap it would make it less work to swap out the 96-98 support for the 99-00, but there are plenty of cars on here including one of my family members that have it done using the 96-98 with NO problems or imperfections at all. I recommend following this tutorial closely as this might help you with your problem http://www.jdmuniverse.com/for...rsion
good luck </TD></TR></TABLE>thanx guy let me see what this site can do for me
zenon8890
Dec 26, 2007 11:56 AM
aznbigman
Apr 24, 2007 03:47 PM
EJ6_MR
Dec 14, 2006 10:34 PM
htownking
10
Oct 15, 2005 04:29 PM
Kicker773
Jun 19, 2003 12:04 AM
