built Crvtec in a 91 hatch
Old Jun 16, 2002 | 06:32 PM
Type S's Avatar
Default built Crvtec in a 91 hatch
hey im thinking about droping my built crvtec motor into a EF. but ive got a couple of questions. i currently have the aem ems (obd1) how difficult will it be to convert the ef to OBD1? also i also want to use my ITR tranny, or would a cable tranny be better? and would it be possible to use an airbag equiped steering wheel from a teg in the ef?
what is the going price for a EF now?
TIA
Old Jun 16, 2002 | 06:46 PM
Blown90hatcH's Avatar
Default Re: built Crvtec in a 91 hatch (Type S)
Run one of my conversion harnesses, OBD1/2 distributor, 4 wire O2 sensor, and OBD1 ecu. Enjoy your day. Email me if interested in an OBd0-to-OBd1 conversion harness. Turbo_EF@yahoo.com
Jason
Old Jun 16, 2002 | 07:24 PM
USDM 4G VTEC's Avatar
well i swa at the track the other day a Cable to hydro conversion ****.. had a cable and like a cylinder wich pulled a hydro tranny wa spretty kewl
spettinger's Avatar
Default Re: built Crvtec in a 91 hatch (Blown90hatcH)
i doubt it would be worth your hassle to try and add an airbag equipped wheel to an EF. as for converting the car to OBD1 ( i thought it already was ) i am not the one to ask. cr vtecs and ls vtecs may not turn out to be all that great, high rpm oil starvation is causing many to blow up. you can run your ITR trans, you will need a bracket to turn your clutch cable sideways to operate the throw out arm. i am not certain if the motor mount would change on the ITR trans to the frame.
Old Jun 17, 2002 | 11:59 AM
Type S's Avatar
Default Re: built Crvtec in a 91 hatch (wreckedhatch)
my crvtec revs to 9200rpm with ease i can go higher but i dont want to *** up the motor.
whats the going price for a 91 hatch with power windows and locks?
Old Jun 17, 2002 | 12:03 PM
SpooN Man's Avatar
Yep you cannot bolt it in. You will have to fab up a mount to an existing kit or start from scratch.
Old Jun 17, 2002 | 01:03 PM
Type S's Avatar
Default Re: built Crvtec in a 91 hatch (SpooN Man)
for the engine or tranny?
Old Jun 17, 2002 | 05:36 PM
Thanks for the great laugh. Revs to 9200 huh? With what fortification?
Old Jun 17, 2002 | 05:57 PM
Type S's Avatar
here is the set up:
b20 block
eagle rods, endyn pistions
micropolished and ballanced crank
speed ballanced pistions and rods
Z10 block girdle
b16a head (stock)
toda b's
portflo retainers
skunk2 valve springs
aem fuel rail
aem fuel pressure regulator
jg im
toda header
PI timing belt
a nice carbonfiber Intake (about 8-9 in in diameter)
and the engine is managed my AEM EMS and my laptop (damn i got to find a cheap laptop for teh damn thing)
so now lets be serious, you dont think i can rev to 9200?
Old Jun 17, 2002 | 06:00 PM
02WRX's Avatar
i'm hoping to rev in that range when i'm done, but i also plan on replacing the pistons, rods, rings, valvesprings, retainers, valves, main bearings, full balance & micropolish, port & polish and a valve job.
i would be surprised if a b20 stock bottom end could handle very much 8k+ driving...but i haven't tried it & won't be finding out myself!
eric
Old Jun 17, 2002 | 06:47 PM
seekerONE's Avatar
Default Re: built Crvtec in a 91 hatch (90CivicEX)
crvvtec can be built to rev....the key word is built
important is balance of crank...b20 cranks not balanced as well as gsr or ITR from factory
i have ridden in friend's b20vtec crx and revved to 9200<on vafc NOT tach>
Old Jun 17, 2002 | 07:12 PM
CRVRX's Avatar
Default Re: built Crvtec in a 91 hatch (seekerONE)
Look at this one.http://www.lhtperformance.net/sample...1.crx.lht.html.
Old Jun 17, 2002 | 07:31 PM
Type S:
Those are good mods, but what about lubrication and engine cooling? What about sleeving for cylinder walk, etc?
John is a friend of mine and does great work.
Old Jun 18, 2002 | 04:38 PM
Type S's Avatar
stock sleeves, moroso crank breather, oil cooler (supposed to be on its way from moroso) oil catchcan, thats about it for now.
Old Jun 18, 2002 | 04:47 PM
spettinger's Avatar
i don't want to be a downer, but that's all well and good that you can rev now, but i the B20 bottom end will fail. it doesn't matter what oil pump you have. that engine will not hold together. start looking for a gsr block soon.
Old Jun 18, 2002 | 06:02 PM
Type S's Avatar
im telling you its gonna last, it has been built properly.
hmmmmmmm maybe for the next block ill go with the 2.0L dart block, i saw it at englishtown, or maybe just a resleeved b20 block.
well, as soon as i find a good tuner ill put the car in its current state on the dyno, im hoping for some big numbers 215whp 150lbft .
Old Jun 19, 2002 | 08:50 AM
Good luck on stock sleeves with 9200...they may last. What about lubrication/cooling? I am not talking about oil cooler or crank breather. If it is built right, you will know what I am talking about. If you dont do this mod that I am refering to, I doubt it will last at those RPMS. Ask your builder if he has left off anything for cooling/lubrication of the internals.
nateswim2002
Feb 11, 2014 06:11 AM
Mekk82
22
Mar 3, 2013 06:45 PM
shortstopNE
12
Jan 23, 2010 04:42 PM
LSej1
Feb 20, 2008 05:00 PM
gato5254
May 3, 2005 02:49 PM
