93 Civic - Only the left headlight works
Old Sep 12, 2007 | 05:31 PM
djjaan's Avatar
Default 93 Civic - Only the left headlight works
hi there, help is needed!
Only the left headlight works in my 93 civic.
I replaced the right headlight - didn't work
I replaced the pigtail (socket) because it was old - didn't work (assuming the wiring is correct)
Is there a fuse for the headlight that I am not aware of and could it have blown. If so, are they separate fuses for each headlight.
Please help
thanks
djjaan
Old Sep 12, 2007 | 05:45 PM
slacks's Avatar
Default Re: 93 Civic - Only the left headlight works (djjaan)
https://honda-tech.com/zerothread?id=1966666
most likely a fuse
the same thing happened with my right high beam
so check your fuses
Old Sep 12, 2007 | 06:07 PM
instrument's Avatar
in the future...fuses should be your first stop.
markstack
Lighting
Oct 7, 2007 06:15 AM
JDM_d15b_eg8
Jun 25, 2006 02:16 PM
JDMtype Eg6
Aug 4, 2005 07:36 PM
Buddhastic
Jun 8, 2004 02:21 PM
Turbo RSX-S
Apr 19, 2004 10:51 PM
