Intermittent solid CEL? bad wiring or ecu?
for about 2 months now ive been getting a intermittent solid cel. outa the blue ill get the check engine wont start and if i just keep turning key off and on to acc until the check engine goes away itll start up and runs like normal. is this signs of bad wiring/connections? or the ecu on its way out?
The first question I ask every time I see this, do you have an after-market alarm? if so, that is the first place I would check. I have seen and heard this type of problem a lot with-in the last 6-8 months, old alarms causing problems. Just something to look into
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CUL8R »</TD></TR><TR><TD CLASS="quote">its your main relay</TD></TR></TABLE>
can you tell me how you know this? im not doubting you that was my guess b/c now my other lude i dont drive often which i know has a "on its way out" main relay is starting to do the same solid cel...
WideBodyTypeR
May 29, 2012 04:36 PM
