should i get the JDM sway bars, or the regular ones for my stock suspension?
Old Sep 12, 2007 | 04:17 PM
ajwiant's Avatar
Default should i get the JDM sway bars, or the regular ones for my stock suspension?
the JDM ones are like 1 mm thicker. will this do anything for my stock suspension?
Old Sep 12, 2007 | 04:20 PM
neo_'s Avatar
Default Re: should i get the JDM sway bars, or the regular ones for my stock suspension? (ajwiant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ajwiant &raquo;</TD></TR><TR><TD CLASS="quote">...will this do anything for my stock suspension?</TD></TR></TABLE>
Yes.
Old Sep 12, 2007 | 04:35 PM
ajwiant's Avatar
Default Re: should i get the JDM sway bars, or the regular ones for my stock suspension? (KOALA YUMMIES)
that wouldn't cause oversteer? for a JDM one with the bushings and brackets it would be like 60 bucks more than oem usdm ones. I might be too lazy to get the jdm one.
Old Sep 12, 2007 | 05:32 PM
94rs-turbo's Avatar
its worth it IMO really new they are about the same price brackets and endlinks are the same all you need is the 23mm bushings and bar
Old Sep 12, 2007 | 08:28 PM
meots98itr's Avatar
baller...i just put skinner tire on the rear...im cheap...
Old Sep 12, 2007 | 08:49 PM
highroller54's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">Not really. Its something like a 14% increase in stiffness (IIRC, for the rear). If you're using all OEM suspension then the only one I'd consider or get is the OEM JDM rear anti-roll bar. I'd never get the front one. </TD></TR></TABLE>
arn't all the front ones the same size? If I'm not misstaken only 98+ itr rear is 23mm in japan.
Old Sep 13, 2007 | 12:01 AM
TastyDragon's Avatar
Default Re: should i get the JDM sway bars, or the regular ones for my stock suspension? (highroller54)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highroller54 &raquo;</TD></TR><TR><TD CLASS="quote">
arn't all the front ones the same size? If I'm not misstaken only 98+ itr rear is 23mm in japan. </TD></TR></TABLE>
correct tha front on both usdm and jdm front is 24mm and rear is 22mm but yes 98 jdm itr is 23mm.
Old Sep 13, 2007 | 03:09 AM
an2ny888's Avatar
Default Re: should i get the JDM sway bars, or the regular ones for my stock suspension? (TastyDragon)
correction.. jdm 98spec front bar is 25mm
Old Sep 13, 2007 | 04:38 AM
Dave_B's Avatar
Having owned (and tracked) the 22mm, 23mm and now the 26mm...
the 23mm defintely makes a difference. Though it's only 1mm, it's (insert the correct percentage here) stiffer and thus helps the car rotate more. If this is just a street car, then I wouldn't worry to much, however if you AutoX or track it, it might be worth your time. Then sell the 22mm and the 23 will only cost your $60.
mn_babyboy
Aug 9, 2008 08:48 AM
Eg_TypeR
Feb 2, 2007 03:43 PM
FOUR-G
Suspension & Brakes
Apr 15, 2005 03:12 PM
Atlas
16
Jun 3, 2004 09:10 PM
jonyb
Feb 3, 2004 01:38 PM
