another tranny noise
Old Sep 12, 2007 | 04:10 PM
GYChris's Avatar
Default another tranny noise
Well, I dont know much about transmissions, but could this problem be synchros?:
While shifting into ONLY 3rd gear it kind of grinds, not a bad grind, just a soft one. But if I shift slowly (hold in clutch for a second longer, then shift) it doesn't make the noise. Could this be a clutch problem, not fully engaging? or is it a transmission problem? I've heard about people having synchronizer problems but I'm not sure if this is a sign.
Old Sep 12, 2007 | 04:14 PM
Ex-Eg-Driver's Avatar
I got that problem too. When im smashin it grinds...driving slow..no grind. I got a GSR tranny. You?
Old Sep 12, 2007 | 04:17 PM
GYChris's Avatar
Default Re: (NINJA-EG)
sorry, forgot to mention.. 92 stock dx tranny, d15b7
Old Sep 12, 2007 | 04:18 PM
Might be syncros. Sounds like the same problem I got. Some Honda guru dude drove my car and told me thats what it was. Syncros or something
Old Sep 12, 2007 | 04:29 PM
Thateguhate's Avatar
use some GM syncomesh, it will get rid of it as long as its in the beginning stages of the synco going bad...
it wont fix it, but it will better lubricate. and you might wanna cut down on the fast shifting, your gonna wear it down twice as fast. Give the sncro enough time to grab and it should last you for a while.
Old Sep 12, 2007 | 04:32 PM
GYChris's Avatar
Default Re: (Thateguhate)
so you are saying it is the syncros?
Old Sep 12, 2007 | 05:18 PM
Default Re: (EGchris)
yes it is (more than likely), basicly what happens is when you shift your sncryos work as teeth grabbing the gear and holding it in place until you shift to the next one and so on..
When you shift slowly your giving the snycros more time to grab the gear making it not jam like it does when you shift quickly..Gotta figure, when sycros are bad they're broken..
Its like sticking a fork in your mouth with a bent tip, chances are your gonna poke yourself and bleed if you eat to fast.. LOL
Old Sep 12, 2007 | 06:25 PM
GYChris's Avatar
hahaha nice metaphor...
anyways, thanks for the help
Old Sep 12, 2007 | 09:40 PM
Mista Bone's Avatar
D Tranny Guru
Only newbies blame the synchros.
I'll bet on a worn shifter fork........why, because I know
Old Sep 12, 2007 | 10:11 PM
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">Only newbies blame the synchros.
I'll bet on a worn shifter fork........why, because I know </TD></TR></TABLE>
wouldnt a bent fork cause a popout?
Old Sep 12, 2007 | 10:16 PM
that guy is the D tranny guru lol
Old Sep 12, 2007 | 10:26 PM
marshun's Avatar
wouldnt that make the shifting shitty for ALL gears? he said only when he's goin into 3rd.
Old Sep 12, 2007 | 10:29 PM
Default Re: (marshun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marshun &raquo;</TD></TR><TR><TD CLASS="quote">
wouldnt that make the shifting shitty for ALL gears? he said only when he's goin into 3rd. </TD></TR></TABLE>
dont argue...hes the guru of all trannys...hahahaha
****, thats what i thought... But I dunno, i just through some possibilitys out there..
Ill tell you this much, it would be a hell of alot cheaper to change the fluid to syncomesh rather than dropping the entire tranny for nothing if the fork is not the problem..
Narrow the possibilites down
Old Sep 12, 2007 | 10:33 PM
Doostur's Avatar
I also say syncros!
Old Sep 12, 2007 | 10:36 PM
marshun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thateguhate &raquo;</TD></TR><TR><TD CLASS="quote">
Narrow the possibilites down </TD></TR></TABLE>
yeah. i think everyone usually just says its the synchros cause people like to slam gears.
but this made me think up a question. does that GM synchromesh work good even when slamming gears?
Old Sep 13, 2007 | 02:40 AM
GYChris's Avatar
i dont usually "slam gears." this usually occurs while shifting at normal speeds. its just that when i shift really slow, slower than normal, i hear no grinding.
Old Sep 13, 2007 | 08:23 AM
but this made me think up a question. does that GM synchromesh work good even when slamming gears?</TD></TR></TABLE>
nope, but it will get him by under normal driving conditions... Trannys arent cheap to work on so its a nice alternative to keep your mind at ease.
Old Sep 13, 2007 | 08:25 AM
plus, we all forgot to mention... That when Syncs go out.... Its usually 3rd gear to go out first. Why i do not know for sure, but I think its the most common gear to be in for city driving and that probably causes more stress to the components.
Old Sep 13, 2007 | 11:42 AM
Mista Bone's Avatar
D Tranny Guru
The resaon 3rd goes out is due to not shifting properly.
2-3 shift is up-right-up, not a straight shot at a slight angle.
Trannys are cheap to work on, worn alum. 1-2 ******* forks causes most 3rd gear grinds. The reason is you just barely out of second and trying to jam third.
Also weak motor mounts will allow the motor/tranny to rock away during the shift and your chasing third gear.
Yes, D tranny Guru.
Old Sep 13, 2007 | 05:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">The resaon 3rd goes out is due to not shifting properly.
.</TD></TR></TABLE>
yeah that is true...even on my gsr tranny.. Funny how you could go straight just about and feel as if your doing nothing wrong.
EG-evokilla
Transmission & Drivetrain
Feb 26, 2009 09:06 AM
88crxdxfastwhip
Mar 16, 2007 10:40 PM
CTR-GSR
Jul 5, 2006 01:04 AM
freud
Jun 21, 2001 10:15 AM
