CRX battery relocation wire size and fuse amp??
Old Sep 12, 2007 | 12:54 PM
alscrx's Avatar
Default CRX battery relocation wire size and fuse amp??
I am finally going to move my battery to the cargo box. I am putting it behind the passenger, hopefully the lid will close with the pc680 battery. Anyway i was going to use a 4 gauge wire to run from battery in cargo box to the engine bay to a distribution block. I was going to cut the ends off those 2 wires in the fuse box(one for starter and one for alternator) and just slide em in the distribution block.
What size fuse should i use?? I am going to use something with a nice fuse holder but i am not shure what size amp fuse to get, I do not want any fires!!
I have read the DIY but i am looking for more people who have done this.
Old Sep 12, 2007 | 01:59 PM
tougeR's Avatar
Default Re: CRX battery relocation wire size and fuse amp?? (alscrx)
Exactly what I'm doing, the 680 does fit in the storage compartment. I used 4awg with a 80amp fuse and hooked it through a distro block, no problems. Been like that for almost a year.
Old Sep 12, 2007 | 03:53 PM
Crx Jimmy's Avatar
you dont need a distribution block. run the 4ga directly to the starter as that is the primary draw. the alternator wire do not remove from fuse box it can stay where it is. just bolt a 8ga from the starter terminal (the same place where the 4ga is bolted) to the fuse box, done! no distribution block needed
If you use a fuse use at least a 100 amp, I would use a 120amp circuit breaker
Old Sep 13, 2007 | 01:09 PM
alscrx's Avatar
Default Re: CRX battery relocation wire size and fuse amp?? (Crx Jimmy)
Really?? So i need to check that out before i buy a dis block. Any pics guys??
Old Sep 13, 2007 | 02:31 PM
Crx Jimmy's Avatar
its very straight forward just look at the starter and the fuse box and put a wire in between
Old Sep 13, 2007 | 02:49 PM
jdm_titan's Avatar
just to be on the safe side read up on it!SEARCH!!!!!!
EFinawesomeman
Dec 31, 2012 09:34 AM
lancerkid06
24
Feb 16, 2009 05:08 PM
crxpwr1
12
Mar 12, 2007 12:12 PM
hatchinprogress
Jun 10, 2006 06:54 PM
TorquelessB16
Audio / Security / Video
Jun 5, 2006 05:28 PM
