Engine Rebuild/Build up question's...
Old Jun 16, 2002 | 05:47 PM
*Boostwerks*'s Avatar
Default Engine Rebuild/Build up question's...
How do I go about...
-Determing exactly what Bore piston I should buy? Is it safe to say that a low mileage ZC is going to need the stock 75mm bore?
-Determining what size berrring's I need. Do I use the old berring's with my new Crower's and do the whole plastigauge thingy?
-How do I tell if a Water pump need's replacing(with out running the motor)
-" same question "....Oil pump.
-Do I need to replace the Crank Thrust berring's?
I feel confident in most of the awnser's to those question's, but I just want to make sure, and also get some opinion's/experiences.
Cause, ya-know this isn't somthing I want to F*CK UP!!
Thank's for any help
Old Jun 16, 2002 | 06:39 PM
Default Re: Engine Rebuild/Build up question's... (Bryson)
NE body?
Old Jun 16, 2002 | 06:53 PM
Jared's Avatar
I never build a motor without boring, always trues everything up so you know everything will be perfect and straight. Bore .25 or .5mm
Always plastigauge, use whatever main bearings come out of the motor and use the numbers on your crank and Crower's recommendation to size bearings for the rods, but always plastigauge afterwards.
Always replace the water pump on a rebuild, they're to cheap not to. Oil pump is iffy, I've never seen one fail, but if it has over 100k and this motor will be subjected to lots of torture, bite the bullet and buy one.
Only if this was a 5speed car. Automatics won't wear the thrust bearings.
Old Jun 16, 2002 | 07:10 PM
Default Re: Engine Rebuild/Build up question's... (Jared)
Great thank's...
Hey if you know...How much does an average machine shop charge for boring an engine out?
Thank's
L_S_i
Mar 24, 2006 04:34 PM
935CRX
Nov 28, 2005 09:04 PM
dstahl01
Mar 7, 2004 04:48 PM
*Boostwerks*
Jun 17, 2002 12:35 PM
KooK
Mar 27, 2002 05:37 PM
