B18A1 into a 91 civic 4 door
Old Jun 16, 2002 | 05:38 PM
Azdrag's Avatar
Default B18A1 into a 91 civic 4 door
Anyone have any info on this swap? Has anyone done this swap WITHOUT using aftermarket mounts such as Hasport or Placeracing mounts? Also which shift linkage do I use? I know that can use one that just has to be modified. I need this info A.S.A.P. My friend has this all torn apart and needs it going soon. Also the car has a ZC in it right now so what else needs to be modified to get going? Thanks everyone.
Old Jun 16, 2002 | 09:08 PM
Azdrag's Avatar
Default Re: B18A1 into a 91 civic 4 door (Azdrag)
Nobody has any info on this one?
Old Jun 17, 2002 | 09:10 AM
red civic standard's Avatar
you will have to get an aftermarket mount kit. HCP makes a kit that comes with adjustable shift linkage for $375 from http://www.jdmshit.com</a>. Good kit. Since he already has a ZC, he has already been converted from DPFI to MPFI. To run a b18 there are three wires that need to be added (knock sensor, o2 sensor, oil pressure sensor). Hasport makes a wire harness for these four wires for $75 (www.hasport.com) For B18 you will also have to get 90-93 integra axles and throttle cable and some different radiator hoses. A lot of good info at <A HREF="http://www.hasport.com" TARGET="_blank">http://www.hasport.com. Hope this helps.
[Modified by red civic standard, 10:11 AM 6/17/2002]
Old Jun 17, 2002 | 09:11 AM
you will have to get an aftermarket mount kit. HCP makes a kit that comes with adjustable shift linkage for $375 from http://www.jdmshit.com. Good kit. Since he already has a ZC, he has already been converted from DPFI to MPFI. To run a b18 there are three wires that need to be added (knock sensor, o2 sensor, oil pressure sensor). Hasport makes a wire harness for these four wires for $75 (www.hasport.com) For B18 you will also have to get 90-93 integra axles and throttle cable and some different radiator hoses. A lot of good info at http://www.hasport.com. Hope this helps.
Old Jun 17, 2002 | 11:09 AM
vbphreak's Avatar
Default Re: B18A1 into a 91 civic 4 door (red civic standard)
It can be done with an engine mount kit (mentioned above). My friend has it in his 90 civic 4 door.
T3KNiQe
25
Feb 8, 2009 08:12 PM
90civSi
Jul 14, 2005 10:35 AM
wid326
Oct 4, 2004 10:36 AM
blackstar
Dec 19, 2003 07:41 AM
