difference between hf and dx
Old Jun 16, 2002 | 05:06 PM
bluebullet's Avatar
Default difference between hf and dx
I just bought a 1990 crx but how can I tell if it is a DX or HF/HX I don't know a lot about CRXs
Old Jun 16, 2002 | 05:09 PM
Urban Business
Guest
Posts: n/a
Default Re: difference between hf and dx (bluebullet)
hf will have 4 injectors dx and hx have only 2 i believe. dpfi (2 jectors) will have the tbody sit verticlay on the intake manifold where as hf will have it on the left side of the intake manifold
Old Jun 16, 2002 | 05:15 PM
wronghand's Avatar
If it's an HF it should have HF on the back. Other differences would be:
HF is MPFI - DX is DPFI
HF has a lower redline
HF has smaller front brakes
HF doesn't have a rear wiper
HF doesn't have a clock in the dash
HF doesn't have a passenger side mirror
Probably more, but that should give you a good idea of which you have.
bluebullet's Avatar
Default Re: difference between hf and dx (TorteX)
umm, thanks but there were only three crx's made in 1990, the si, dx, and I'm not sure which but either an hx or hf, I know it starts with an "h" I know it is not an si. I have a 5-speed transmission does that ID it in any way?
Old Jun 16, 2002 | 05:17 PM
bluebullet's Avatar
Default Re: difference between hf and dx (wronghand)
thanks wronghand, mine has the clock, both mirrors and the wiper on the back, also the dual point FI. I think you answered my question bro! Thanks, All the Si's have sunroofs right?
Old Jun 16, 2002 | 05:20 PM
wronghand's Avatar
Bingo! That is correct.
Urban Business
Guest
Posts: n/a
yeah all si's have sun roofs. clock mirrors etc were all extra **** you can buy from dealer.
Old Jun 16, 2002 | 05:31 PM
bluebullet's Avatar
one last question, what is the engine code for my motor, can I make it a mini-me? I know it is a 1.5.
Old Jun 16, 2002 | 05:33 PM
wronghand's Avatar
D15B2, and yes you can use that block for a mini me set up.
Old Jun 16, 2002 | 05:38 PM
bluebullet's Avatar
Sorry to be a pain in the a** wronghand, I have a 99 si, I just bought this 90 CRX DX, I can conceivably purchase a head from a 6th gen civic that has vtec and use that even though it is a 1.6? Y8 I believe, because I think my head is jacked on my current engine.
Old Jun 16, 2002 | 06:58 PM
wronghand's Avatar
Yes you can. You can use either the Y8 or Z6 head. Do a search, there is a lot of info on the swap. My knowledge on the mini me set up is pretty limited.
Mechman456
Nov 11, 2006 11:11 AM
drumminforev
Nov 3, 2006 05:31 AM
HondaHeddie
Sep 23, 2006 09:58 PM
5litereater
Jun 24, 2004 06:01 PM
NightHawkC5
Feb 22, 2003 07:05 AM
