How difficult is CV boot/Axle replacement
Old Sep 11, 2007 | 07:14 PM
JDMTEG98's Avatar
Default How difficult is CV boot/Axle replacement
I recently purchased a Used 96 Accord. There is a slight noise when ever a left turn is made. I heard that the CV boot or possible the axle might need to be replaced.
How hard are these to do ? Should I just take it in somewhere to have it done or is this a fairly easy DIY.
Thanks in advanced
Old Sep 11, 2007 | 07:21 PM
The-Kid's Avatar
Default Re: How difficult is CV boot/Axle replacement (JDMTEG98)
Use search button. and be sure to click on the archive option
For me, it was easy because I have my steering knuckle out. I would say, it was pretty easy. Just patience and time. If you have a rusty wheel area or live near salt/wet area, I suggest just bringing it to a shop. Most of the time, it is so rusted up, it's impossible to remove without a press.
The only part of this job you have to worry about is...
-remove the axle from the hub
-remove the axle nut.
Old Sep 11, 2007 | 07:23 PM
bowser_cd5's Avatar
its easy if you have all the tools...first check ur cv boot to make sure its the boot, which it probably is...just see if its torn...if your rotors and hubs are rusted then good luck lol your probably ganna have to take it to a shop if its rusted
Old Sep 12, 2007 | 07:26 AM
AFAccord's Avatar
Default Re: (bowser_cd5)
If indeed, the axle needs replacing then you should most certainly attempt it yourself. (provided you're not a mechanical klutz) If you have to buy a few tools (36mm socket namely) then it's still worth the money saved. If you pay a shop to do it, and watch them, you'll be kicking yourself for not doing it at home.
I know there are write-ups around here. Just search.
Old Sep 12, 2007 | 08:10 AM
guymontag's Avatar
I regret thinking that I could pop the lower ball joint without a bearing puller. I was way wrong; even with the bearing puller I had to use serious force. I even put my air wrench onto the bearing puller's threaded bolt. That popped it open, heh. Learn from me and rent the appropriate tools the first time around.
Old Sep 12, 2007 | 08:19 PM
Grandhustleman86's Avatar
Default Re: (guymontag)
I used Advance Auto Parts loaner tool program for the ball-joint puller kit....also for the axle sockets too....just need a 1/2" 2-3ft long breaker bar and a lil elbow grease and those pesky axle nuts are a easily removable....NEVER FORGET upon reinstall....lock the axle nut .
Old Sep 13, 2007 | 03:59 PM
Honda-Master's Avatar
hope this helps
http://www.hondaaccordforum.co...m.htm
Vitesse
Jul 24, 2006 10:09 AM
calean
Nov 10, 2004 06:04 AM
BigDawwg6969
13
Jan 5, 2004 07:12 PM
John
Mar 19, 2002 06:58 PM
TeginRAGE
Jul 17, 2001 06:17 AM
