CV issues...
Old Mar 19, 2002 | 06:49 AM
John's Avatar
New User
Default CV issues...
So it seems that my car did not only suffer cosmetic damage from the tire retread that I hit on the interstate, it seems I have other damage as well. My left wheel has thick, dirty grease all over it, symptoms of CV boot tear.
Now I did a search, and in one thread (https://honda-tech.com/zerothread?id=137530), someone suggested that the entire axle should be replaced. Is this something that you all would recommend, or should I just buy a new packet CV boot and replace that?
Old Mar 19, 2002 | 07:16 AM
Accord94DX's Avatar
Default Re: CV issues... (DunReit)
You could repack the boot, so long as it isn't clicking when turning and whatnot. It is a lot easier to slap a new axle in though.
Old Mar 19, 2002 | 07:23 AM
scrubachu's Avatar
Default Re: CV issues... (Accord94DX)
replacing the entire cv is easier IMO. to repack the boot, you have to bang out the outer joint with a hammer, then put on the new boot, and then put the joint back together when you fill it with grease. you have to pull the entire axle anyways to replace the boot. IMO its easier to just throw in a new axle, and not worry about the boot slipping off if you didnt tigheten the outer or inner ring that holds the boot in.
Old Mar 19, 2002 | 07:30 AM
Gennady's Avatar
New User
Default Re: CV issues... (scrubachu)
Please clarify. Do you mean axle when you say CV? From what I understand the CV or Constant Velocity boot is the rubber springy thingy at the end of an axle. So is it easier to replace the boot or axle?
Old Mar 19, 2002 | 07:31 AM
Accord94DX's Avatar
Default Re: CV issues... (Wont be beat)
He means the whole assembly.
Old Mar 19, 2002 | 07:34 AM
Gennady's Avatar
New User
I see.
scrubachu's Avatar
yeah, i meant the whole assembly. my boot started to slip off and leaked grease. instead of replaceing the boot, after condisdering swapping boots, it was just easier to replace the whole alxe.
Old Mar 19, 2002 | 09:15 AM
John's Avatar
New User
Any particular recommendations for what brand axle I replace my original one with? Normally I'd go with an OEM replacement, but I know I'll probably break it in the future since I have an Xteme PP w/ SS disc and a Quaife. I've also heard mixed opinions on rebuilds...
Old Mar 19, 2002 | 10:49 AM
Accord94DX's Avatar
http://www.driveshaftshop.com talk to frank. $300 for a pair of stage ones. I have been running them on my F22b2 with 65 shot/ACT XTSS no problems!!
Old Mar 19, 2002 | 10:53 AM
John's Avatar
New User
I was looking at their products, but I didn't see any Stage 1's for Accords... I only saw Stage 2's...
What is the primary difference between their CV axles and OEM CV axles? I see that they list "1117 billet housings and a induction heat treated solid bar," but how does that compare to the OEM design?
Also, do you know if the rubber boot uses a more durable compound?
[Modified by DunReit, 2:56 PM 3/19/2002]
Old Mar 19, 2002 | 10:55 AM
Accord94DX's Avatar
What is the primary difference between their CV axles and OEM CV axles? Is it the type of steel used?
they make em. trust me. The use needle bearings in the tulip joint and stronger metal all around
Old Mar 19, 2002 | 11:03 AM
4doorH22's Avatar
Whichever axle you get, if you want to keep your ABS, make sure the axle has the ABS sensor ring on it!
I ordered mine from http://www.raxles.com. They make a great product, but unfortunately they sent me the wrong driver's side axle (easy to screw this up on a hybrid). The passenger side axle is fine, but is missing the ABS sensor ring so no ABS for me.
I've been meaning to return the axle, but haven't gotten around to doing so yet.
Old Mar 19, 2002 | 03:57 PM
urbanlegend21's Avatar
New User
Default Re: CV issues... (4doorH22)
Dave- just buy the ring from an auto parts store, when i replaced my axle at the track the other weekend the guy told me that he has just taken the ring off old axles and used it again
whatever you do never buy a split boot or try putting a plastic bag over it with zip ties and running on the track, you end up with a bigger mess then you started with
Old Mar 19, 2002 | 05:49 PM
4doorH22's Avatar
Default Re: CV issues... (urbanlegend21)
Good to "see" you Morgan, it's been a while. Thanks for the info on the ABS ring. Plastic bag with zip ties? LOL
Old Mar 19, 2002 | 06:06 PM
smokin rubber's Avatar
and lots of duck tape. Oh well it was worth a try once
Old Mar 19, 2002 | 06:58 PM
John's Avatar
New User
Default Re: CV issues... (smokin rubber)
duct tape and plastic wrap with zip ties... g h e t t o
but i'm sure if i was desparate, i'd try those options too...
Jimster480
Jan 22, 2010 10:58 AM
sohcef9
15
Oct 2, 2005 06:39 AM
gtowni3
Dec 24, 2004 08:09 AM
sinfulDB1
Dec 2, 2003 10:53 AM
davidbui
Jan 13, 2002 04:17 AM
