ball joint
Old Jun 16, 2002 | 04:38 PM
WHATS VTEC's Avatar
Default ball joint
i have a 93 civic ex, i was taking out the tranny and one of my buddies wanted to help- so i put him on axle duty i showed him how to do it on the pass side, the come the drivers side he said he had it and next i know is that he hammered the tip of the ball joint and mushroomed the tip..... so how bad am i screwed?????
Old Jun 16, 2002 | 05:12 PM
WHATS VTEC's Avatar
Default Re: ball joint (low93ex)
someones got to know? cost on to replace it? how to replace it? could i do anything without replacing it...
Old Jun 16, 2002 | 05:15 PM
97hb's Avatar
I think its only like $30 for a new joint. Only problem is you need a press to get it out . I would take the lca off and take to a shop to have it done.
Old Jun 16, 2002 | 05:16 PM
WHATS VTEC's Avatar
Default Re: ball joint (97hb)
would i be better off just buying some gsr brakes for $100??????than replacing that
Old Jun 16, 2002 | 05:19 PM
shawnhayes's Avatar
$100 from the dealer. How do I know? Did it. But, I mushroomed it with a puller (forgot to leave the doggone castle nut on --- arrrrgh).
Shawn
Old Jun 16, 2002 | 05:21 PM
WHATS VTEC's Avatar
Default Re: ball joint (shawnhayes)
worst of all i was not even the one who messed it up onm my own car, but i am not sweating it cause he is a good buddie,. so the ball joint is $100.00????
Old Jun 16, 2002 | 05:38 PM
shawnhayes's Avatar
Ball joint and labor all done. $100. Joint is $30, installation is $70. PIA unless you can do it yourself. (I don't recommend it, and I have my own press).
Shawn
Old Jun 16, 2002 | 05:44 PM
WHATS VTEC's Avatar
so i should just by those gsr brakes i can get for 100? instead of replacing the ball joint on my ex brakes
Old Jun 16, 2002 | 06:25 PM
WHATS VTEC's Avatar
upupupupupupupupup
Old Jun 18, 2002 | 06:44 PM
shawnhayes's Avatar
Don't know. Is the balljoint on the replacement knuckle good? If you GET the knuckle with the brakes for $100, it's probably a beter deal.
Shawn
Old Jun 18, 2002 | 07:25 PM
mechanik's Avatar
I mushroomed mine.
You need to get a die and fix the threads. When mine was mushroomed kinda, it would start to thread on, and then keep on spinning. I took my impact gun to it and held it on, finally it spun on faster than the joint was spinning. Problem fixed!
I also dremiled some of the threads on the bottom
Old Jun 18, 2002 | 08:31 PM
onefastcx's Avatar
Default Re: ball joint (mechanik)
i would just buy the brakes cause you are probley going to want to do a upgrade later, so it i up to you i am just giving you my oponion, cause i would go with bigger brakes!!
liquidzorch
Transmission & Drivetrain
Apr 18, 2013 05:29 PM
blnielson
Nov 25, 2007 01:46 PM
crx18c1
10
Apr 17, 2007 10:17 PM
GruvyTune
Jul 2, 2002 12:47 AM
