lsv build
Old Sep 11, 2007 | 06:05 PM
Rony_typer's Avatar
Default lsv build
lsv set up
bottom end
stock bore b18b block
stock ls rods with arp rod bolts
ctr pistons
type r water and oil pump
type r oil pan
ctr crank pulley
head
cosmetic head gasket(to lower the compretion a lil and ad more clerance)
port and polish type r head
skunk2 valves
skunk2 springs and retainers
skunk2 pro 3 cams
skunk2 pro cam gears
rc 410 injectors
aem fuel rail and reagulator
walbro 250 fuel pump
performer x intake mf
and im missing a throtle body
custom 4-2-1 race header
flow master mufler with a strait thru no cat.
my question is what throtle body should i use a 68mm or a 70 since thats all im missing and will i have a problem with clerance since the cams are real big. plus have any body use the secondary injector on the performer x a lil info abouit them would be nice. thx and fell free to coment good or bad.
Old Sep 11, 2007 | 06:28 PM
killerpenguin21's Avatar
Default Re: lsv build (Rony_typer)
that is a very iffy piston choice, i hopw you know what your oding with that. your cr will be almost 13, although i see you kind of balanced that out with the pro 3's, which is a giant cam.
look into the new professional products tb's i just got mine it look really nice. 70mm taperd to 68. port match that to whatever manifold you have and it should be a ncie combo.
Old Sep 11, 2007 | 06:35 PM
Rony_typer's Avatar
Default Re: lsv build (killerpenguin21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerpenguin21 &raquo;</TD></TR><TR><TD CLASS="quote">that is a very iffy piston choice, i hopw you know what your oding with that. your cr will be almost 13, although i see you kind of balanced that out with the pro 3's, which is a giant cam.
look into the new professional products tb's i just got mine it look really nice. 70mm taperd to 68. port match that to whatever manifold you have and it should be a ncie combo.</TD></TR></TABLE>
what do u meen by 70mm taperd to 68.
Old Sep 11, 2007 | 08:20 PM
the opening at the intake side is 70mm and follows a factory 2mm taper down to 68mm at the manifold side to help with throttle response.
Old Sep 11, 2007 | 11:21 PM
ToeJam's Avatar
professional products tb's almost oem
Old Sep 12, 2007 | 12:10 AM
Chris Tune's Avatar
pro3 on stock bore stroke b18? wow...
Old Sep 12, 2007 | 04:33 AM
Default Re: lsv build (Chris Tune)
probably th eonly way he will balance out the cr given by the pct's
Old Sep 12, 2007 | 07:05 AM
pgpbubble's Avatar
Yeah but what about P2V contact?
Old Sep 12, 2007 | 12:42 PM
Brick Top's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rony_typer &raquo;</TD></TR><TR><TD CLASS="quote">ctr pistons
any particular reason why you chose those pistons?
Old Sep 12, 2007 | 01:22 PM
Rony_typer's Avatar
Default Re: lsv build (Brick Top)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brick Top &raquo;</TD></TR><TR><TD CLASS="quote">
any particular reason why you chose those pistons?</TD></TR></TABLE>
i was looking for 13.1 compretion so i coud move the cams but them i ran in to p2v problems so i got the cosmetic head gasket 4 a little more clerance. . the motor is going to be tune on 110 octane this way i dont lose power retarding the time .
Old Sep 12, 2007 | 01:50 PM
its not the point that your gonna need to tune it on 110 is the point that you cant drive the car on anything but.
Old Sep 12, 2007 | 02:01 PM
b20beast978's Avatar
if its going to be a daily driver you have no choice but to use 110 or else your goign to be pinging liek crazy. i think p30's would have been a bettrr piston choice since they weigh less, have better flame travel and they yield around 11-5 11-7 CR depending on what head and gasket combo just my .02
Old Sep 12, 2007 | 04:39 PM
Rony_typer's Avatar
Default Re: lsv build (b20beast978)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20beast978 &raquo;</TD></TR><TR><TD CLASS="quote">if its going to be a daily driver you have no choice but to use 110 or else your goign to be pinging liek crazy. i think p30's would have been a bettrr piston choice since they weigh less, have better flame travel and they yield around 11-5 11-7 CR depending on what head and gasket combo just my .02</TD></TR></TABLE>
the car is going to be a weakend car so 110 is no problem.
does any body have any sujestion about 68 or 70mm throtle body, im thinking about skunk2
Old Sep 12, 2007 | 05:10 PM
or get the one i mentioned for 130... and not have to worry about it sticking.
Old Sep 12, 2007 | 06:45 PM
Rony_typer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerpenguin21 &raquo;</TD></TR><TR><TD CLASS="quote">or get the one i mentioned for 130... and not have to worry about it sticking.</TD></TR></TABLE>
can i buy this one online (what web site ) or can i just go to like full throtle and get it.
Old Sep 12, 2007 | 07:03 PM
mx621's Avatar
i would say if you must have 13:1 comp, tune it on e85 if its avalible.its like 2.90 per gallon and is the equivilent to around 105 octane or so. i would say a pro3 is to large for a 1.8L motor. a pro2 would probly work better.
Old Sep 12, 2007 | 07:25 PM
Rony_typer's Avatar
Default Re: lsv build (mx621)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mx621 &raquo;</TD></TR><TR><TD CLASS="quote">i would say if you must have 13:1 comp, tune it on e85 if its avalible.its like 2.90 per gallon and is the equivilent to around 105 octane or so. i would say a pro3 is to large for a 1.8L motor. a pro2 would probly work better. </TD></TR></TABLE>
thats what alot of people is telling me but i already purchase the cams and cant returned them so i figure i should give them a shot and if it dont work ill buy a b20 block and tranfer everithing over.
im just dyen to finish it and just drive it. its been a long time.
Old Sep 12, 2007 | 07:30 PM
J_White's Avatar
Sounds like a nice setup. Wish I could help you out but goodluck with the build.
Old Sep 12, 2007 | 08:32 PM
im just dyen to finish it and just drive it. its been a long time. </TD></TR></TABLE>
i have a bad feeling it will not last very long due to some piston to valve contact unfortunatley.
the tb can be had at vsracing.net or kteller sells them also.
Old Sep 13, 2007 | 07:12 PM
Rony_typer's Avatar
the tb can be had at vsracing.net or kteller sells them also.</TD></TR></TABLE>
so what shouldi do. if i lower the comp it wont move the cams and what about the cosmetic turbo gasket wont the bring the comp to mid 12?
Superqwak
Feb 23, 2012 08:04 PM
nrowttocs4484
Sep 2, 2011 09:07 PM
1990_integra_DA9
60
Sep 9, 2009 07:50 PM
reserved
19
Jul 10, 2008 03:36 PM
JayDeeEmm
13
Jun 27, 2008 01:01 PM
