Cleaning rubber off your car from previous burnouts?
I know now how to prevent it from sticking, by spraying a light lubriant on it before.
But i currently have rubber everywhere and it smears when i try to clean it off. Any suggestions, Seems like simple green works semi good, but is there anything out there that takes the S#@t right off?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zubaltec »</TD></TR><TR><TD CLASS="quote">WD-40 and cheap paper towels FTW!</TD></TR></TABLE>
damn right
damn right
i notice a fresh coat of wax helps the stuff not stick so bad. i use wax to take it off too but im sure it takes alot more work than what others have suggested.
i just cleaned mine off this weekend with denatured alchohol. it took me about two hours. i used to use some stuff called burnout gaurd from a local speed shop. i think i am going to start using it again. you just spray it on and wipe it off and the rubber will come right off.
lol i have the same problem right now, my white 4dr teg has rubber all down teh side, all the way to the back doors lol
never heard of the wd-40 thing, ill have to give it a try
soo before you guys go race you spray wd-40 on the car to keep it from sticking as well?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF »</TD></TR><TR><TD CLASS="quote">wd-40 ? </TD></TR></TABLE>
We have 4 cans in the trailer at all times 3 for the rubber and 1 to use to work with
Every pass we clean the sides and then after event under the fenders ---- Then follow over the WD-40 with Quick Detail
Works great !
Works great !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV »</TD></TR><TR><TD CLASS="quote">i notice a fresh coat of wax helps the stuff not stick so bad. i use wax to take it off too but im sure it takes alot more work than what others have suggested.</TD></TR></TABLE>
A good Pre Wax will take that staff off, after that apply a coat of wax and maintain with a regular Spray- N- Wax, works great
paper towels will damage your paint. use a microfiber towel.
I have used WD-40 in the past. Don't really know how good it was for the paint, then again it was race car.
Modified by Rogue108 at 4:59 PM 9/13/2007
so im hearing, wd-40, dishwashing soap, prepsol, wax.....
none of this stuff will harm the paint???? i know wax and dishwashing soap such as dawn wont, but wd-40, prepsol and i think someone mentioned lacquer or paint thinner, none of these things will harm the paint?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanGreenMachine »</TD></TR><TR><TD CLASS="quote">so im hearing, wd-40, dishwashing soap, prepsol, wax.....
none of this stuff will harm the paint???? i know wax and dishwashing soap such as dawn wont, but wd-40, prepsol and i think someone mentioned lacquer or paint thinner, none of these things will harm the paint?</TD></TR></TABLE>
Dishwashing soap strips wax and is very harsh BUT so is drag racimg on your paint, rocks and rubber flying at your paint hard lol
Just finished rota's car. I used WD-40 first. Worked ok, but as the towel got full it began to smear.
Then I tried Acatone, that worked a little better.
Then I went back the minerial sprits. worked the best of the 3 and is much cheaper.
I'll try prepsol next time.
for some of you with pretty paint jobs, it may be worth it to look into some clear-bra for the doors / fenders.
I know 3m has some film that can be applied, i'm sure other companies offer this as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanGreenMachine »</TD></TR><TR><TD CLASS="quote">will prepsol harm the paint?</TD></TR></TABLE>
