code 43
Old Jun 16, 2002 | 04:23 PM
chad's Avatar
Moderator
Default code 43
43=Fuel supply system circuit.
how do i fix this?
Old Jun 16, 2002 | 08:32 PM
InevitableRace's Avatar
Default Re: code 43 (Chad)
take the light bulb out
Old Jun 16, 2002 | 11:24 PM
Sonny's Avatar
It could be as simple as your gas cap not being on tight enough. Check it, reset the ECU, and try gain.
Sonny
Old Jun 17, 2002 | 03:51 AM
Todd Reid's Avatar
Default Re: code 43 (Sonny)
this is usually a bad 02 sensor, in my experience.
has happened twice to me; start the car up and no light for about 2 minutes. then the check engine light comes on. if you drive for a while, then shut off the motor and start it again, does the light go out? i put a meter on my O2 sensor, and it was acting "lazy" so I replaced it. problem solved!
good luck
Todd
PS this was on a 94 OBD-I Teg motor.
ryanminer
Oct 17, 2008 08:52 AM
BABE-BOY
Jan 8, 2008 08:35 PM
solofthesouth
Apr 30, 2006 08:22 AM
vtecfiendsh
Feb 12, 2003 10:10 AM
