My 89 CRX Si Cranks but wont start can any one help????
I put a new dizzy cap and button on it because it was throwin a code. It doesn't have a code now but it still wont start can any one help. thanks for any help.
its probably the distributor. did it die on you while you was running it cause if it did it could be your distributor,timing belt, or fuel pump
get someone to turn the key an see if you can hear the fuel pump kicking in, or smell for gas, i had the same problem on an ls hatch an it was the distributor. check your timing belt to see if its tight to make sure it did not skip a track
jerryscherry
13
May 8, 2014 10:08 PM
cd5jdm96
May 2, 2014 08:12 AM
D'PEXi
Apr 7, 2009 07:41 PM
