Main Relay rplaced and wont start at all
Old Sep 11, 2007 | 11:47 AM
Acidcrakker's Avatar
Default Main Relay rplaced and wont start at all
Okay so Im doing the main relay today as well. I got the old relay out, but when takeing it out like a smack, I used pliers and created a spark while takeing them out. Now I have the old one out and the new one in and it wont start at all. Are there fuses for the main relay? Someone help, I need this thing up and running before 6pm
Old Sep 11, 2007 | 12:00 PM
NATE92SI's Avatar
Default Re: Main Relay rplaced and wont start at all (acidcrakker)
what car is this? And did you check all the fuses in the cabin?
Old Sep 11, 2007 | 12:20 PM
Default Re: Main Relay rplaced and wont start at all (NATE92SI)
its a 1992 Prelude SI, 2.3L engine.
Besides the fuse box under the dash, and the one in the top left of the engine compartment, are there any more fuse boxes?
Old Sep 11, 2007 | 12:27 PM
nonvteclude's Avatar
does anything happen when you turn the key or is it just dead? do all your lights work? what exactly sparked
Old Sep 11, 2007 | 12:29 PM
Default Re: Main Relay rplaced and wont start at all (nonvteclude)
okay thanks, I checked it out, it was a fuse. Bah, thanks again.
Old Sep 12, 2007 | 04:48 AM
jamesjarvis85's Avatar
Where is the Main Relay on a 93 Prelude SR Located? And How to replace it??
Old Sep 12, 2007 | 05:26 AM
Default Re: Main Relay rplaced and wont start at all (jamesjarvis85)
I would imagine its in the same place as the 92 SI. Underneath the dashboard driver side. You have to take off the bottom panel to get to it.
https://honda-tech.com/zerothread?id=925622
https://honda-tech.com/zerothread?id=1664950
https://honda-tech.com/zerothread?id=1729919
https://honda-tech.com/zerothread?id=1775690
More threads that I used. Its easy to replace. One 10mm bolt holds it in place, and it snaps in and out of the wire hire harness.
Old Sep 12, 2007 | 05:35 AM
94Vtecluder's Avatar
So your car starts now?
Old Sep 12, 2007 | 06:08 AM
Default Re: Main Relay rplaced and wont start at all (94Vtecluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">So your car starts now?</TD></TR></TABLE>
It always did. But at times it gave me more ***** than I wanted. Especially when it was hot. I trouble shooted everything else. I Had all filters changed, timing checked out, new spark plugs, wires and distrubutor cap. And it still wouldnt start up sometimes and I had to let it sit for a few mins and then it would work. I did the relay yesterday, that one bolt holding it up was a bitch to remove but I got it out and replaced it with a new one. Blew a fuse to while doing it. Lesson learned disconnect postive battery terminals while working on electrical.
Old Sep 12, 2007 | 09:57 AM
Another way to check the relay is if your car isn't starting smack the side of your dash where the relay is. If it starts then yes it's your relay. And yes you should always disconnect battery when doing eletrical. I jumped my headlights while splicing and installing the harness for the JDM headlights. Scared me too!
EK B18c
22
Apr 21, 2012 03:08 PM
DarkBB4
Jul 14, 2006 05:27 AM
el_Presidente
May 11, 2003 01:36 PM
