drivers side window issues
Old Sep 11, 2007 | 09:53 AM
autoxthis's Avatar
Default drivers side window issues
I have a 91' crx with manual windows and my drivers side windows is a joke. If I roll it up or down, it will seesaw off the tracks and end up cockeyed and sends me into a fury! I have removed the door panel and plastic cover to see what the problem is and I don't notice anything wrong. In fact the pass. side is the same visually as the drivers side.
The drivers side window was broken before I owned the car and (with receipts) the window was replaced as well as the regulator. So it all should work right? wrong! The only thing that I noticed is the drivers side window does not seem to fit as snug in the vertical tracks as the passenger side. Maybe the replaced window is poor quality replacement?
Any ideas on WTF is wrong would be great. I will call the shop that installed on Monday and ask ???
Old Sep 11, 2007 | 10:29 AM
black0hatch's Avatar
Default Re: drivers side window issues (autoxthis)
ya you probably got a shitty window. you can adjust it though. but since you got receipts take that **** back and have them do it.
Old Sep 11, 2007 | 10:35 AM
SOHCinWA's Avatar
All late 80's through the 90's Hondas do that.... It caysed by the rubber seal that the window goes in .... It curls up right in the corner near the mirror... Every single Honda I have owned or worked on has that issue over time.
Old Sep 11, 2007 | 07:07 PM
Street Racer X's Avatar
Default Re: (SOHCinWA)
the rubber tracks in the window could be worn or the plastic rollers that are in the tracks could be too worn out. Sounds like a good time to upgrade to power windows
Old Sep 11, 2007 | 10:15 PM
autoxthis's Avatar
Default Re: (Street Racer X)
mmm power windows sound good
CivicRaping
Nov 15, 2020 12:47 PM
crxaddikt
17
Jan 13, 2015 04:04 AM
deerman2701
Nov 27, 2007 05:59 AM
autoxthis
Sep 11, 2007 09:53 AM
LB CRX
Jan 15, 2003 03:56 PM
