96 spec ITR complete swap into a 00 gsr???? MORE HELP NEEDED>>>>
Old Sep 11, 2007 | 08:30 AM
joseph510's Avatar
Default 96 spec ITR complete swap into a 00 gsr???? MORE HELP NEEDED>>>>
for this swap i also need a obd2b to obd2a conversion harness right?
if i use the conversion harness are any plugs on my gsr harness not going to work for my type r motor, becuase of the fact that im using the type r ecu with the gsr harness???
thanks for the help
Old Sep 11, 2007 | 09:35 AM
INTEGRA TYPE-XI's Avatar
Default Re: 96 spec ITR complete swap into a 00 gsr???? MORE HELP NEEDED>>>> (joseph510)
If I remember right, you will need to re-wire knock sensor and rpm.
Old Sep 11, 2007 | 10:58 AM
joseph510's Avatar
Default Re: 96 spec ITR complete swap into a 00 gsr???? MORE HELP NEEDED>>>> (INTEGRA TYPE-XI)
are all the wires there, and just need to be set up in a different sequence?
darkoe671
Feb 20, 2010 05:28 PM
ants4g63
27
Apr 9, 2009 11:03 AM
joseph510
Sep 10, 2007 10:42 AM
90sihbw89crxfrnface
Mar 24, 2005 12:17 PM
dozer1313
Oct 29, 2004 01:23 PM
