weird noise coming from driver side front..
Old Sep 11, 2007 | 07:30 AM
KickStart2323's Avatar
Default weird noise coming from driver side front..
well i have a 91 crx si w/b16 and i only hear the noise when there is weight being pressed on the driver front during a right hand turn more than 20 degrees and going faster than 20mph...it dose NOT make it when i turn right only when there is weight being pressed against it.....
it almost sound like the tie rod is pressing against the brake sheild making a grinding/ticking noise...
im pretty sure its not the axle b/c it only dose it when the body rolls to the driver side......
anybody ever have this problem?
Old Sep 11, 2007 | 08:35 AM
canospeed200's Avatar
Default Re: weird noise coming from driver side front.. (KickStart2323)
Did u check the clearence on the alternator because i had the same problem it might rubing against the engine bay if you you have b16.
Old Sep 11, 2007 | 09:08 AM
Default Re: weird noise coming from driver side front.. (canospeed200)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canospeed200 &raquo;</TD></TR><TR><TD CLASS="quote">Did u check the clearence on the alternator because i had the same problem it might rubing against the engine bay if you you have b16.</TD></TR></TABLE>
no i will check it out....... i can feel the vibration/noise on the fake pedal, left of the clutch pedal
Old Sep 11, 2007 | 03:21 PM
this was my problem never would have looked there..thanks man for the help..
now i just got to change the tranny mount to solve the problem...
thanks again
Old Sep 11, 2007 | 03:37 PM
24TEN's Avatar
PHANTOM MENACE
Excuse my ignorance, but how would changing the tranny mount solve the problem? (honest question)
Also, when doing the swap did you pound that side of the engine bay to give clearance for the alternator? Or was it swapped before you got the car or someone else did the work?
Old Sep 11, 2007 | 04:08 PM
garageEF's Avatar
Default Re: (24TEN)
sounds to me like you need to dent the frame some more....
Old Sep 12, 2007 | 09:56 AM
Default Re: (24TEN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN &raquo;</TD></TR><TR><TD CLASS="quote">Excuse my ignorance, but how would changing the tranny mount solve the problem? (honest question)
Also, when doing the swap did you pound that side of the engine bay to give clearance for the alternator? Or was it swapped before you got the car or someone else did the work?</TD></TR></TABLE>
b/c the bushing in the tranny mount is shot, meaning the motor rocks back and forth....i just didn't out 2 and 2 together when the noise started....a new bushing will sovle this problem...i have had the car for over 3 years so this was a new sound to me......oh and i bought the car w/ the swap but the guy was my neighbor and i helped him put the motor in, so i new where the car came from and what type of driver he was...
Old Sep 12, 2007 | 10:48 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: (KickStart2323)
Makes sense, might as well replace them all. Post up if it does infact solve the problem. Good luck!
Old Sep 12, 2007 | 10:53 AM
Default Re: (24TEN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN &raquo;</TD></TR><TR><TD CLASS="quote">Makes sense, might as well replace them all. Post up if it does infact solve the problem. Good luck! </TD></TR></TABLE>
well i already replaced the other 2 not to long ago, so imm just going to order one bushings, they are hasport mounts which are lifetime warranty i just cant have my car sit for a week wile it gets shipped their and back, so i don't mind paying the $$
Old Sep 12, 2007 | 12:02 PM
here is a vid of the noise i was hearing...the first time it happen it scard the **** out of me..
A is 4 PiMp
Sep 29, 2006 07:29 PM
BlueIntegraBoy
Aug 19, 2005 03:46 PM
xZeler8
Dec 21, 2004 04:07 PM
tunes12
12
Jun 12, 2004 09:47 AM
bwan24
May 25, 2003 01:07 PM
