Won't go in gear
Old Sep 11, 2007 | 07:29 AM
Overlook's Avatar
Default Won't go in gear
Hey guys. I just traded my car for a 92 Hatch, Sunday, with a D16Y7 turbo setup. We drove it two hours home, I drove it for a few minutes when I got home, and I drove it to work and back yesterday, which my work is about a mile from my house. So I get into the car today, start it up, it won't go into gear. So I turned it off, and notice when the car is off, it goes into gear just fine. I also noticed the clutch pedal was sticking, I'd press it in, and it'd stick and I'd just use my foot to bring it back, or sometimes it would come back. The car is extremely low, and it has a oil pan leak, and he said a leak with the Speed Sensor. Now, the car wouldn't start without the clutch in, but when I pushed the clutch in it started. I was told the speed sensor leaks tranny fluid, maybe this could be the problem? I found a similar thread, but I wanted to see what you guys thought. Thanks alot!
Old Sep 11, 2007 | 10:45 AM
Thateguhate's Avatar
Default Re: Won't go in gear (Overlook)
master cylinder, or uneven clutch wear....
pullback your carpet and check for leaks coming down the firewall in the interior side of your car...
If not id drop the tranny and check the pressure plate, clutch and flywheel.
Old Sep 12, 2007 | 08:13 AM
92_civic's Avatar
Default Re: Won't go in gear (Thateguhate)
check the slave cylinder also
viper_boy403
Aug 20, 2008 06:48 PM
Overlook
Sep 11, 2007 10:27 AM
scrEaMO Kyle
Nov 3, 2005 11:49 AM
Luchini
Oct 16, 2005 11:15 AM
40oztoFreedom
Jun 3, 2004 11:40 AM
