The Integra I just bought has a strange idling problem...
Old Sep 11, 2007 | 07:04 AM
AH Tow EX's Avatar
Default The Integra I just bought has a strange idling problem...
In neutral, at a complete stop it will stay at around 3,000 RPM.
After driving around for a while, it will go down to about 2,000 RPM at Neutral at a complete stop.
Then eventually if I drive it a lot it will go down to 1,000 RPM at a complete stop.
but the revs won't go down until i come to a complete stop. It will stay up at about 3K until I stop completely.
It's really annoying.
It's a 1998 GSR. I think it either has an ITR Intake Manifold or a BLOX IM. B18C1 Block. Not sure of the head, but I'm sure it's a GSR head...
Any help would be greatly appreciated.
Old Sep 11, 2007 | 07:27 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: The Integra I just bought has a strange idling problem... (AH Tow EX)
Check everywhere around the manifold and brake booster for leaks or any hoses not connected, clean your IACV, that should be a good start and hopefully you will find a hose not connected that will fix your problem.
Old Sep 11, 2007 | 07:51 AM
AH Tow EX's Avatar
Default Re: The Integra I just bought has a strange idling problem... (St Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Check everywhere around the manifold and brake booster for leaks or any hoses not connected, clean your IACV, that should be a good start and hopefully you will find a hose not connected that will fix your problem.</TD></TR></TABLE>
where's the IACV?
Old Sep 11, 2007 | 08:03 AM
St Jimmy's Avatar
* B A N N E D *
https://honda-tech.com/zerothread?id=699787
https://honda-tech.com/zerothread?id=1564019
https://honda-tech.com/zerothread?id=1575913
Old Sep 11, 2007 | 08:07 AM
AH Tow EX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=699787
https://honda-tech.com/zerothread?id=1575913</TD></TR></TABLE>
i don't have an FITV. but i'll take a look at the last thread. thanks
Old Sep 12, 2007 | 09:50 PM
AH Tow EX's Avatar
cleaned out the IACV and it worked for a little bit. but when i started it back up later it was idling high again... any other suggestions?
Old Sep 13, 2007 | 06:47 AM
AH Tow EX's Avatar
bump. still have the problem. any suggestions?
Old Sep 13, 2007 | 07:12 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: (AH Tow EX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AH Tow EX &raquo;</TD></TR><TR><TD CLASS="quote">cleaned out the IACV and it worked for a little bit. but when i started it back up later it was idling high again... any other suggestions?</TD></TR></TABLE>
How long later? Your car is suppose to idle high when its first warming up, so if the engine sat and cooled for a bit it was probably just warming up again.
Old Sep 13, 2007 | 07:55 AM
AH Tow EX's Avatar
Default Re: (St Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">How long later? Your car is suppose to idle high when its first warming up, so if the engine sat and cooled for a bit it was probably just warming up again.</TD></TR></TABLE>
well, it worked for a little bit. then a few hours later driving home, it had the high idle. then again this morning driving to work. it would be at around 3K RPM then when i get below 2MPH, it went down to about 1.5K RPM.
what should i do?
Old Sep 13, 2007 | 08:09 AM
St Jimmy's Avatar
* B A N N E D *
what should i do?</TD></TR></TABLE>
Wait for the car to reach operating temp. Or get remote start and start the car from inside your house where you can see what its idling at untill it warms up.
Old Sep 13, 2007 | 08:10 AM
AH Tow EX's Avatar
even after warm up, the idle stays high.
Old Sep 13, 2007 | 08:22 AM
St Jimmy's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AH Tow EX &raquo;</TD></TR><TR><TD CLASS="quote">even after warm up, the idle stays high.</TD></TR></TABLE>
Then your at the same position I am. Ive taken apart my intake manifold and cleaned everything, made sure everything is hooked up where it suppose to, ive done almost everything but cant figure out what it is. I just live with it.
Old Sep 13, 2007 | 08:23 AM
AH Tow EX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Then your at the same position I am. Ive taken apart my intake manifold and cleaned everything, made sure everything is hooked up where it suppose to, ive done almost everything but cant figure out what it is. I just live with it.</TD></TR></TABLE>
what kind of IM do you have?
NVMYDC
Jan 6, 2015 05:39 PM
paawk2000
May 12, 2005 12:21 PM
