d16z6 question
Old Jun 16, 2002 | 02:21 PM
SOUTHCREX's Avatar
Default d16z6 question
Dose any know where the water line thats on the back alternator side of of a z6 block? Im running a pre obd z6 and I dont know if i hook it up to something or just plug it. Thanks
Old Jun 16, 2002 | 03:22 PM
SOUTHCREX's Avatar
Default Re: d16z6 question (TEAM GARAGE SHIFTDOWN)
anyone" I need too know asap
Old Jun 16, 2002 | 03:35 PM
xXx Justin xXx's Avatar
the only hose i can see on the back of mine on that side goes to what i am guessing is the water pump? a black matal box looking thing that you can see on the back of the block on the tranny side, under the intake manifold? the other four hoses are coolant lines i guess, two go to the fire wall, and the one under the distributor goes to the bottom of radiator, the one on the front side(tranny side) go to the top of the radiator. everything else i see is vacuum lines or sensors? at least that how mine was when i put it in my rex? and i just put it in like 3 weeks ago. hope i helped.
if you can be more specific i would be glad to go out and look around for what you describe and tell you where it is at on mine? just post away.
Old Jun 16, 2002 | 05:26 PM
SOUTHCREX's Avatar
Default Re: d16z6 question (bstdvtecRx)
Its a little nipple for a hose to go on on the back side right next to the alternator, its come of of that main black tube in the baack of the motor.
JdmJohnny210
Nov 10, 2012 04:53 AM
coco502
20
Jan 4, 2010 08:05 PM
SOHCEK-Turbo
Jan 17, 2005 12:30 PM
RTW DC2R
Dec 16, 2003 09:20 PM
