Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Civic Sedan Jacking Point
Old Sep 11, 2007 | 03:33 AM
hydengr's Avatar
Default Civic Sedan Jacking Point
Folks,
I have an 05 sedan and rotate my tires at every other oil change, approx. 6,000 miles. I like to keep the tires on the same side, so it's convenient to jack the car up from a single point (using my floor jack). I know where the proper jacking points are, front and back, but once my floor jack is positioned there, I can't lower the car onto jackstands.
So... I've been positioning the jack at a point on the body which lines up being approx. under the front door handle, allowing both tires to come off the ground at the same time.
This is my 4th Honda sedan (2 Accords, one Civic) and I've done this with all of them with no perceived ill effect.
Anyone have a better way (short of a lift, of course).
Thanks
Old Sep 11, 2007 | 03:41 AM
thinknology's Avatar
Default Re: Civic Sedan Jacking Point (hydengr)
Sounds good to me, as long as it's on the frame.
Old Sep 11, 2007 | 04:04 AM
daddy's Avatar
Default Re: Civic Sedan Jacking Point (thinknology)
if the place where your putting hte jack wasnt strong enough to hold the car up you'd see it crushing. so if you dont see any signs of that id say ur good!
Old Sep 11, 2007 | 09:29 AM
InanimateCarbonRod's Avatar
Default Re: Civic Sedan Jacking Point (daddy2be)
I use the front/side jack point just behind the wheel and I pump the jack up enough so both front and rear tires come off the ground. I don't use jackstands because I don't plan on going under the car for changing wheels.
If you're worried about not having a jackstand under there, there are some new tools that function both as the jack and the jackstand.
Example:
http://www.sears.com/shc/s/p_1...7000P
Old Sep 11, 2007 | 10:27 AM
hydengr's Avatar
Default Re: Civic Sedan Jacking Point (InanimateCarbonRod)
Understand not needing to get under the car to rotate tires, although I usually take the opportunity to stick my head under there and look around... albeit briefly.
Never tried to lift both front and rear tires from the front reinforced jack position... I'll give it a shot next time.
The jack-jackstand tool that you referenced is sweet... Never seen nor heard of one before... Wonder if it ever goes on sale...
Thanks to all.
Old Sep 11, 2007 | 11:28 AM
fventura03's Avatar
i dont think you should jack up your car from that point (center point by door handle). it's not reinforced there, it might buckle eventually...
Old Sep 11, 2007 | 11:38 AM
Default Re: (fventura03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 &raquo;</TD></TR><TR><TD CLASS="quote">i dont think you should jack up your car from that point (center point by door handle). it's not reinforced there, it might buckle eventually...</TD></TR></TABLE>
No, no definetly not. But the frame comes past the front tire a bit not quite to the door handle, and if jacked up from that spot can get both tires off the ground.
I still don't like it personally though.
SidCivic
Honda Civic (2006 - 2015)
Nov 3, 2017 07:01 PM
newFitOwner
Honda Fit
May 3, 2015 03:16 PM
back2boostin
17
Oct 16, 2014 03:12 PM
6doorsentra
Jan 15, 2007 02:31 PM
dazco
13
Sep 20, 2002 06:14 PM
