idle rpms went up a little after valve adjustment
.004 is tight what car is this on i know ls is rec not tighter then .005 intake .006 exhaust b16 and gsr are a bit tighter which may be your .004 but i believe it is about the same i will check let u know
Integra LS
B18B
Intake: 0.003" - 0.005" (0.08mm - 0.12mm)
Exhaust: 0.006" - 0.008" (0.16mm - 0.20mm)
It doesn't make sense that the idle get's affected by the valve adjustment
B18B
James648405
Jun 1, 2010 12:32 PM
vlc92189
Nov 14, 2007 06:52 AM
