Oil Shoting out of the exhust i don't know what it is plz help
Old Sep 10, 2007 | 09:28 PM
xaznstyleracerx's Avatar
Default Oil Shoting out of the exhust i don't know what it is plz help
Will heres the thing i have a 94 Stock DC motor in a 91 integra Ls.
The problem i'm having is the exhust is shoting out oil and a cloud of white smoke It comes and gose when i leave the car alone it dosen't shot out any white smoke only wen i am driving the car it shots out.The check engine light isn't on and the ecu isn't throwing out any codes also the motor runs great expect for the white smoke here and there the car and motor was sittin for about 1 year dosen't seem like the headgasket is leakin too so i don't know what it is.Also i did throw in a bottle of injecter cleaner in the car and the gas gauge dosen't work so i think it might be that the cleaner was runing with oil with no gas but wen i poored it in it had gas in the gastank what do u guys think it could be ? PLZZ NEED HELP ASAP
Thanxs for the help
Old Sep 10, 2007 | 09:38 PM
doood's Avatar
been there done that
Default Re: Oil Shoting out of the exhust i don't know what it is plz help (xaznstyleracerx)
you're burning coolant somewhere
Old Sep 10, 2007 | 09:44 PM
Dartanian's Avatar
Sounds like your headgasket even though it isn't leaking externally since both oil and coolant are making their way into the combustion chamber. Do a compression and leakdown to confirm.
Old Sep 11, 2007 | 10:23 AM
Default Re: Oil Shoting out of the exhust i don't know what it is plz help (Dartanian)
alrite i'll try a leak down test and a compression test as will to double check if its the headgasket thanxs guys i'll let u know how it gose and it only shots out sometimes cause the car runs good and no lack of power is loss + wen the car stays idling and i don't drive the car its fine no white smoke but wen i drive the car for like 10-15 mins the white smoke comes bck but its not as bad its just i smell oil coming from it but i'll try out the leak down test and compression test frist thanxs alot guyz.
Old Aug 21, 2010 | 06:24 AM
civic addict's Avatar
how do you do a leak down and a compression test?
Old Aug 21, 2010 | 08:43 AM
el crapitan's Avatar
it may just be water. which is normal.
try the comp test though if you're concerned
blue89hatch
May 7, 2008 06:29 PM
Squallie
10
Oct 1, 2005 05:00 PM
REEMB18C1
22
May 4, 2005 06:34 AM
Honda97
Mar 10, 2005 05:06 PM
