did a big oops today at work
Old Sep 10, 2007 | 05:42 PM
Mavrick's Avatar
Default did a big oops today at work
hey all, I was doing a cylinder leakdown test today at work, then i had to play with the ignition switch and forgot i still had the cylinder leakdown tester installed on the #4 cylinder. I cranked the engine for a few rolls until i realized i still had the tester installed with air still going to it. Do you think I would of bent anything?
Old Sep 10, 2007 | 06:14 PM
hondamark35's Avatar
Default Re: did a big oops today at work (Mavrick)
well cylinder leakdown- rocker arm assembly was off right? that means all the valves were closed. i'm gonna have to say you have damaged nothing. pretty confident.
Old Sep 10, 2007 | 09:03 PM
Mavrick's Avatar
Default Re: did a big oops today at work (hondamark35)
rocker assembly was on, i was more concerned about rods though
Old Sep 10, 2007 | 09:12 PM
Jim Truett's Avatar
No. You just pushed the air back into the compressor. Still, you could never reach combustion pressures if you had 100psi in the cylinder and cranked it over.
Kyoh
Aug 27, 2007 07:16 PM
drumminforev
Oct 20, 2006 05:19 AM
92integraVTECgsr
Nov 20, 2005 08:31 PM
92integraVTECgsr
Nov 20, 2005 06:07 PM
Vanilla4215
Nov 10, 2002 11:18 PM
