Is this normal or a problem? Oil leak? (PICS)
Old Jun 16, 2002 | 12:34 PM
Zubz's Avatar
Default Is this normal or a problem? Oil leak? (PICS)
I never noticed it happening in the past. Kinda looks and feels like some oil buildup. Is it normal...or is there something that I should check?
[Modified by ZubzSi, 4:38 PM 6/16/2002]
Old Jun 16, 2002 | 12:54 PM
g2teg's Avatar
Default Re: Is this normal or a problem? Oil leak? (ZubzSi)
You probably want to check and replace(if necessary) your valve cover seals. They might just have been blown out of place. Then when you put your valve cover back on torque the bolts out, that gives it a more even seal.
Old Jun 17, 2002 | 06:23 AM
Crazydave's Avatar
Default Re: Is this normal or a problem? Oil leak? (g2teg)
replace the valve cover bolt seals
Old Jun 17, 2002 | 06:43 AM
GM2000ITR's Avatar
New User
Default Re: Is this normal or a problem? Oil leak? (Crazydave)
Be sure that when you replace the seals that they are clean and dry. The dry, clean rubber will provide a perfect seal against the metal, provided, of course, that the metal is clean and dry too.
Old Jun 17, 2002 | 07:50 AM
Zubz's Avatar
so you guys think i should check and replace the seals that go under the bolts right? not the one big gasket that goes around the whole valve cover...because i dont think thats leaking at all.
anybody have a part number for me?
Old Jun 17, 2002 | 09:41 AM
smokin rubber's Avatar
you can get them from http://www.manhonda.com they are called vlave cover grommets. If you have not replaced the valve cover seal in a while it might need replacing, and your valves might need an adjustment too.
em1gangsta
Jan 1, 2008 09:42 PM
iLovPhoKing
Jan 2, 2006 08:07 PM
inane
Mar 5, 2005 09:50 PM
yeegsr
Dec 13, 2004 07:32 AM
mulpha
Jan 14, 2004 04:01 AM
