oil sandwhich plate
Old Sep 10, 2007 | 01:31 PM
DrivinVtec's Avatar
Default oil sandwhich plate
http://cgi.ebay.com/ebaymotors...ZWDVW
I need one of these an im wondering if anyone has used this? I need one. anyone recommand anything else?
maybe this one would be better
http://cgi.ebay.com/ebaymotors...wItem
maybe this one?
http://spideraccessories.store....html
Old Sep 10, 2007 | 01:56 PM
nonvteclude's Avatar
Default Re: oil sandwhich plate (DrivinVtec)
i use the golden eagle sandwich plate. the only problem i had was the prelude oil filter didnt fit, i ended up getting a filter for an insite and all was well.
Old Sep 10, 2007 | 02:28 PM
InvaderTrax's Avatar
I myself will probably be using the first one, or something similar
Old Sep 10, 2007 | 02:35 PM
96vtecI4's Avatar
Check out http://www.maxspeed-motorsports.com.
Old Sep 10, 2007 | 03:19 PM
DrivinVtec's Avatar
Default Re: (InvaderTrax)
the only reason why i wouldnt use that first one so much is i hate changing oil an haven **** drip over the DP
Old Sep 17, 2007 | 09:20 AM
g_dub's Avatar
Instead of buying that, check the prelude turbo thread, there is a place to tap in on the side of the head and if you need any additional ports (ie, for turbo oil feed, oil pressure gauge, ect) the just get a T or a 4 way spliter for the line. I can imagine that the oil filter sandwich is not the best answer to your problem. Hope it helps.
Old Sep 17, 2007 | 10:06 AM
DrivinVtec's Avatar
Default Re: oil sandwhich plate (g_dub)
im using that port now for turbo an oil pressue gauge, but i dont want to rob to much oil to the head.
Old Sep 17, 2007 | 10:17 AM
the major problem with putting a t with the pressure gauage and feed line is you do not get an accurate reading. the nice thing about the sandwich plate is that you will have more volume than a t fitting will have so things will be more accurate for feed lines, pressure gauge and oil temp gauge.
Whatislove
Honda Civic (2001 - 2005)
Jul 10, 2009 12:03 PM
turbof22b
Nov 28, 2006 07:02 PM
JDMTurboCivic11
Dec 3, 2004 07:26 AM
b16supertuner
May 13, 2004 08:38 PM
SiClone
Mar 5, 2003 04:30 PM
