Rear wheel seizes
Old Sep 10, 2007 | 01:10 PM
fbjunkie53's Avatar
New User
Default Rear wheel seizes
I have an 88 Accord LXI. When I put it in gear (either reverse or forward) it will move a few feet, then the right rear wheel will lock. I put it in the other gear (reverse or forward) and it still freezes. If I engage and disengage the parking brake, the wheel will free up, but then seize again after a few more feet of driving.
I've disassembled the rear drum brake, inspected for stuck pads, obstructions, etc. and found nothing unusual. I cleaned the drum and wheel with brake cleaner, but the condition persists. Brake fluid is at normal levels and there are no signs of leaks. I'm not experiencing any other symptoms of brake problems.
Is this a brake issue or could it be something else?
Old Sep 10, 2007 | 02:04 PM
02 accord's Avatar
Default Re: Rear wheel seizes (fbjunkie53)
Bearing? Remove all the brake stuff and try spinning the hub by hand and see if it freezes then.
street_ride14
Sep 3, 2011 08:35 AM
globy123
Sep 21, 2009 11:56 AM
george34
Feb 4, 2006 06:01 PM
cccya
Oct 25, 2002 06:06 PM
