90-93 rear wheel hub bearing interchangeable with 94+?
when changing the wheel hub bearings it is rec. u use the one for your specific car!
I believe the rear disc barke "assemblies" are very identical in 90-01 integras
double check tho..
double check tho..
yes they are identical i am a mechanic and the two cars share the same part number for the rear wheel bearing should be able to swap it with no issues
axis11
Aug 3, 2013 05:18 AM
FSRslug
Apr 21, 2009 03:04 PM
