fan trouble
why wont my fan work???
when i plug up the plugs it will not turn on but
when i have it directly wired up to the battery it works fine
94 teg with gsr
94 teg with gsr
check grounds... if all is good probably a bad coolant temp sensor... if you want to check it you can jump the connector at the coolant temp sensor,unplug it and jump the connector with a paper clip... thanks please let me know asap... thanks again
phaphon
12
Sep 15, 2010 09:37 PM
Spoon_Nazi
15
Mar 17, 2003 05:28 PM
