low fuel light?
is there anyway to check to see if your low fuel light works without running the car dry? i have run my car to all but .75 of a gallon and it didnt kick on what can i do to fix it or do i have to run the car more to get it to kick on?
id say your best bet is to get a couple gallons of gas and put it in a gas jug and go drivin til you run out and then you will know. if it dont work then just take out the cluster and replace the little bulb
Im not sure if this works for honda's as well, but doing work on a friend's subaru, with the fuel pump assembly out, the sending unit or whatever the device was out, so it was marking the tank as "E" and set his gas light off when we had it on accessory.
same thing happens to me, I have a 95 civic ex and i've done the "run out of gas to see if it works" i've done it till the car doesn't want to start because of gas and the light never works, PLEASE HELP!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ ITO »</TD></TR><TR><TD CLASS="quote">same thing happens to me, I have a 95 civic ex and i've done the "run out of gas to see if it works" i've done it till the car doesn't want to start because of gas and the light never works, PLEASE HELP!!</TD></TR></TABLE>
I have a '95 EX and I'm pretty damn sure it doesn't have a gas light.
That's a nice way to expletive up your fuel pump.. All of that sludge and **** from the bottom of the tank is introduced into your fuel pump/lines, and that's bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 »</TD></TR><TR><TD CLASS="quote">That's a nice way to expletive up your fuel pump.. All of that sludge and **** from the bottom of the tank is introduced into your fuel pump/lines, and that's bad.</TD></TR></TABLE>
Its great for your fuel filter and all 4 of your injectors!
i learned the hard way that my gas light doesnt work. i have a 2000 si that i recently purchased. i was unaware of the small size of the fuel tank and ran out of gas on the interstate. i had a vw before that held almost 15 gallons, the si only holds about 11. i take it that these gas lights are a common problem.
91ED7Si
21
Mar 4, 2002 09:12 AM
