Oil orifice o-ring?
Finally putting my head back on my gsr block, does the oil orifice on the block between cyl 2 & 3 have an o-ring? Don't remember seeing one when i took apart the motor.
Yeah, got the cam cap o-ring, its just I bought a gasket set and i have an o-ring left over, wasn't sure if it went to the block oil orifice. thanks alot
so does the o-ring go under the metal jet or above the jet, and between the head gasket and block, from the looks of the picture, it goes below the oil jet down into the block
i did not remove the oil jet from the block, there are no threads to thread a bolt in, does the o-ring inside the block or above the block
