Easy question about dx to mpfi
Old Jun 16, 2002 | 11:12 AM
SOUTHCREX's Avatar
Default Easy question about dx to mpfi
Ihave every thing wired up right ecept for one lil prob, on the distributer all wires are hooked up ecpet for two white wires, two on the plug and two on the distributer. dose it mater what way they go?Thanks
Old Jun 16, 2002 | 12:38 PM
SOUTHCREX's Avatar
Default Re: Easy question about dx to mpfi (TEAM GARAGE SHIFTDOWN)
anyone? Need info asap
Old Jun 16, 2002 | 01:31 PM
Malgerus's Avatar
There is a recent thread that covers this ENTIRE swap on here... just do a search.
Old Jun 16, 2002 | 02:02 PM
SOUTHCREX's Avatar
Default Re: Easy question about dx to mpfi (89_Y_49)
I did a seach and i found out everything i need to know and have it all done but it says nothing about two of the white wires on the dx plug and the si distributer being the same color and what way they hook up. dose it not matter ?
Old Jun 16, 2002 | 02:35 PM
Urban Business
Guest
Posts: n/a
if you strip back the loom in the dizzy harness you will see 3 wires. grey, black and a single white. inthe grey and black wires are 2-4 other wires. (grey and black wires are really just insulation but look like wires) the single wite wire thats not insulated w/ the other wires is a power wire for the dizzy. need to be hooked up to the single white wire NOT next to any solid wire w/ a stripe. if you loko at the 7 pin plug this will all make sense. white and white/stripe both are a pair. orange and orange/stripe are a pair single white wire in the connector thats not near anything else goes to the power wire
Old Jun 16, 2002 | 02:38 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: Easy question about dx to mpfi (TorteX)
Oh yeah, I know about the two white wires.
In reality, one is white with a very faint blue line which in our cars has faded down to nothing.
So, don't worry about the wires.
If the car won't start, then swap the two wires.
it only works one way.
Old Jun 16, 2002 | 02:40 PM
Urban Business
Guest
Posts: n/a
Default Re: Easy question about dx to mpfi (Spaceballs the lunch box)
well if you strip back the loom you will see the wire colors perfectly.
Old Jun 16, 2002 | 03:10 PM
SOUTHCREX's Avatar
LOL i did strip the wire all the way back to the distributer and it all looked the same.thanks for the help
Old Jun 16, 2002 | 05:26 PM
Urban Business
Guest
Posts: n/a
you strip it form dizzy to rest of engine harness. you went the wrong way
JJ's civic
May 6, 2009 02:55 PM
chad
Jun 14, 2008 08:05 AM
mcgee*
Mar 20, 2007 05:31 PM
paybac4223
Mar 19, 2003 11:00 AM
HybriDNA
Feb 12, 2003 05:44 PM
